I had been needing another project over the winter, so decided it was time to tackle my water meter readings. Living in the desert, water consumption is important but for whatever reason our utilities haven’t made it easy to get real-time measurements and don’t subsidize commercial meter readers yet. I started out with an SDR to try to scan any of my meters, but struck out - I’m guessing they’re either polled 1/mo or possibly encrypted based on my meter documentation.
Next thought was a Flume meter reader, but they were a bit expensive without a utility rebate and I hated the idea of going through batteries every 6-12mos if I was lucky. My meter isn’t far from the house, but we’ve got a gravel yard, the meter’s in a little well, and it’s just such a PITA to deal with batteries. I decided to try out a used unit from an online auction site, for a little over $100, and see if I could get it hardwired.
There’s a simple video online for hardwiring here, and I went with the pin connection rather than the battery terminal route.
Some items I used for the setup:
- Waterproof receptacles and plugs from Digi-Key. They even have little caps for the receptacles if you decide to run with a battery down the road. Grand total for a couple of sets - about $20 shipped.
- 20 meters of outdoor 20 gauge/2 connector wiring, which upon receipt may not be the best quality outdoor wiring, but we’re going to run with it. $20 shipped.
- The video has an adjustable AC/DC converter, which I started out with to try at 3.6V, but turns out it can handle at least up to 5V so I’ll use a spare 5V wall wart for simplicity - that adjustable converter bounces around a bit and you never know what you’re going to get. The adjustable converter was $18 shipped, but I’ll return later to use the spare 5V unit.
Some semi-finished pictures (I’m going to let it run for a week or so, then rewire the 5V wall wart):
Installation of receptacle and plug connection.
The trench I dug from the house out to the meter.
The Flume reader happy in its little cave. I had to dig out a bunch of silt to get better access to the meat of the meter, and then backfill with yard stone to hopefully promote drainage if and when we ever get rain.
Got the meter calibrated and it seems to be pulling data. Looking forward to using it for monitoring leaks in our irrigation system (by figuring out how much is used during our typical 2hr cycle when no leaks are present, for example), and showing my sustainably-minded family just how much water we’re using on the reg.
My recommendation for the Flume team for version 3 is to have a solar powered, battery backup option. I’d give that a shot but it was a bit more than I was capable of designing. I’m welcome to ideas if you’ve got them, though!
