Harmony Configuration not pulling in New Activity
After doing a search in the Forum I was unable to find anything related to my current dilemma. I recently setup a new Activity on my Harmony remote, but it isn’t showing the update list when I try to setup on an Automation from the UI. When I look in the file created by the integration it shows up in that list, but it doesn’t show up as an option when it comes to certain idea. I don’t know if this is one situation where I should create the automation in yaml, or if something just isn’t updating very often.
I know they are no longer making the Harmony remotes, but until it completely stops functioning I will continue using it.
You said you see the new activity in your .conf file. What about in the Logitech Harmony Hub integration? You should see 1 device with 2 Control entities. One of those entities allows to select the Activity. Do you see the new Activity there?
Have you tried to manually edit an automation yaml to enter the appropriate logitech device id’s?
Nick
Thanks for the Help, I did get it figured out. I set it up to be when the State Changes to the Automations it was able to work as intended.
