I tried to configure this integration but I have this type of error in My home-assistant.log:
2021-07-04 18:36:58 ERROR (MainThread) [homeassistant.components.climate] Error adding entities for domain climate with platform harmony_ac
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 383, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 588, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 614, in add_to_platform_finish
await self.async_added_to_hass()
File "/config/custom_components/harmony_ac/climate.py", line 155, in async_added_to_hass
self._current_fan_mode = last_state.attributes['fan_mode']
KeyError: 'fan_mode'
2021-07-04 18:36:58 ERROR (MainThread) [homeassistant.components.climate] Error while setting up harmony_ac platform for climate
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 258, in _async_setup_platform
await asyncio.gather(*pending)
Thanks suxlala.
I tried to change my configuration:
- platform: harmony_ac
name: Condizionatore Piano Terra
remote_entity: remote.harmony_hub
device_id: 75313445
min_temp: 23
max_temp: 30
target_temp: 27
target_temp_step: 1
temp_sensor: sensor.temperature_158d00025ee70a
customize:
operations:
- cool
- dry
no_temp_operations:
- dry
fan_modes:
- auto
# - night
but the error seems to be the same:
2021-07-05 17:18:33 ERROR (MainThread) [homeassistant.components.climate] Error adding entities for domain climate with platform harmony_ac
2021-07-05 17:18:34 ERROR (MainThread) [homeassistant.components.climate] Error while setting up harmony_ac platform for climate
I’m on a NUC with Hassio core 2021.6.6.
So I don’t think the config would be the issue. Have you tried to remove and reinstall, reboot, clear cache etc?
Thanks again @suxlala.
I have cancelled Climate integration from Hacs rebooted HA and reinstalled.
The error seems to be generated when the component try to get the last_state that should be null while it result “Not None”.
