Mostly it works as expected, except that the generated harmony_REMOTENAME.conf (in my case harmony_harmonyhub.conf) seems to lack information.
It lists all 4 activities I have, (3 of my own and a -1 for PowerOff) but the Device commands list has only 3 devices. And the ones it chose seem random (e.g. I have 3 chromecasts, it shows 1).
In reality, my hub has 7 devices, 1 “light” (emulated_hue) and 1 sensor.
It seems like a bug… Does anyone have any thoughts?
How would your harmony hub have the emulated hue light and a sensor? The only devices that should show up are the devices which are controlled by the harmony hub itself and controllable from the harmony app
The sensor is not related, it’s the Nest thermostat’s sensor.
As for the emulated hue lights, that just worked as described. I added emulated_hue: to my configuration.yaml, and ran discovery on the hub, and it just found switches defined in HA. I think that’s exactly the purpose of emulated_hue, no?
I’m still not sure what your original question is. Maybe it will help if you post a copy of the *.conf file that the harmony component generated and what devices you think it’s missing
See the the generated conf I have.
Notice that it’s missing many devices Harmony knows about (see the screenshot for examples)
Specifically:
It has: Living Room Chromecast, LG TV, Kodi.
It’s missing: Sony AV Receiver, BenQ Projector, Sony PS4, Basement Chromecast, Nest thermostat, Nest Home/Away sensor (and maybe also the hue lights, though that’d be some kind of loop since they’re defined HA)
Activities
24058002 - Watch TV
24096318 - Watch a movie
-1 - PowerOff
24053421 - Play PS4
Device Commands
41596596 - Living Room Chromecast
41687064 - LG TV
PowerOff
PowerOn
PowerToggle
Number0
Number1
Number2
Number3
Number4
Number5
Number6
Number7
Number8
Number9
Mute
VolumeDown
VolumeUp
PrevChannel
ChannelDown
ChannelUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
Select
Stop
Play
Rewind
Pause
FastForward
Record
Return
Menu
Teletext
List
Green
Red
Blue
Yellow
Guide
Info
Exit
Aspect
3D
AD
App/*
AvMode
EzAdjust
Home
InputAv
InputComponent
InputHdmi1
InputHdmi2
InputHdmi3
InputHdmi4
InputNext
InputRgb-Pc
InputTv
MyApps
Q.Menu
T.Option
Tv/Radio
UserGuide
41648002 - Kodi
Mute
VolumeDown
VolumeUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
Select
Play
Rewind
Pause
FastForward
Return
Subtitle
Info
Audio Tracks
Break
CloseProgram
CloseWindow
Context Menu
Yes, some of those devices are defined in activities, not all.
I’d love to do that, but could you be more specific? How do I run that? I found the method is defined in .homeassistant/deps/pyharmony/__main__.py but I’m not sure how to run it with the arguments it expects.
It looks like the it’s crashing while writing the kodi device’s commands, I believe it’s caused by the Apple sepcific characters stored in the command text as shown in the attachment. Can you try removing the harmony*.conf file and the kodi device from your harmony hub and see if that solves it? I don’t have my kodi instances programmed into my hub since I use HASS to control them
What would it take to fix the crash? It’s especially annoying because all the symbols are coming from Harmony, for some reason they consider Kodi to be an “Apple” device. I’m running on a pi.
The reason I don’t want to remove Kodi from Harmony is that the harmony remote is my main controller for Kodi (other than the Android app).
Were you able to fix this?
I seem to have a similar problem, though with far less activities and devices.
What I use:
Sony Bravia TV
PioneerVSX920 Receiver
Raspberry Pi OSMC + HASS
And two audio devices (Amazon Echo and Panasonic all)
All are plugged in the Receiver.
I setup 4 activities:
TV = Switch on TV and Receiver
Kodi = Switch on TV and Receiver and HDMI to receiver
Music 1 Receiver to Echo
Music 2 Receiver to Panasonic all
The only activity that shows is the Echo
I don’t see any devices…
Seems as though Kodi is the problem because of the non-standard character, expected to be an apple thingy.
Both Kodi and HA are running on a Raspberry Pi 3.
I do have HA installed using the VENV method, why would that matter though?
