Harmony Hub integration missing devices list
Hi guys ,
I’ve recently insalled the Logi Harmony Hub integration in my HA setup and it seems to work fine .
However there is only an option to interact with the activities menu and not with the devices one as you normally would expect .
For instance : I tried to find a way to control only my TV thru the Hub but there is no option to do it .
Is this actually normal or I’m missing something ?
Thanks for your answers in advance :slight_smile:
This is normal. Read up on how to use the remote entity
Hi Petro ,
And thanks for replying so quickly .
It may sound stupid but , where exactly you are adding the snippets for the Harmony hub ? I did try to do it straight into the Config.yaml but nothing happens .
My main goal is to create an On/Off ( switch ) button for a certain device within the main UI .
Hope that make sense a bit and will look forward for your reply .
