Harmony Hub not working after 0.103.2 update?
Am I wrong? Noticed yesterday that my scripts for harmony hub end with an error, on both hass.io and pip3 installed versions (got both).
Error ends with:
voluptuous.error.MultipleInvalid: must contain at least one of entity_id, area_id.
Before this, things were working fine
I can give the answer myself, entity-id needs to be added now:
Hi Han, glad you worked out the entity-id requirement!
I have not got anywhere near as far as you appear to have with the harmony controlling my SamsungTV.
Would you mind sharing your customizations for this… would save me a lot of head scratching if I could copy yours and change a little for my setup.
It consist of a few items.
First when your harmony hub is connected to HA it makes a file harmony_living_room.conf (living_room depends on the name in configuration.yaml).
Basically it contains all items you learned to the harmony hub.
    "Activities": {
        "-1": "PowerOff",
        "41444235": "Watch TV"
    "Devices": {
        "Dyon Satellite Receiver": {
            "commands": [
                "PowerToggle",
                "0",
                "1",
                "2",
                "3",
                "4",
                "5",
                "6",
                "7",
                "8",
                "9",
                "Mute",
                "VolumeDown",
                "VolumeUp",
                "ChannelPrev",
                "ChannelDown",
                "ChannelUp",
                "DirectionDown",
                "DirectionLeft",
                "DirectionRight",
                "DirectionUp",
                "Select",
                "Stop",
                "Play",
                "Rewind",
                "Eject",
                "Pause",
                "FastForward",
                "Record",
                "SkipBack",
                "SkipForward",
                "Menu",
                "Teletext",
                "Green",
                "Red",
                "Blue",
                "Yellow",
                "Guide",
                "Info",
                "Exit",
                "Goto",
                "Source",
                "Tv/Radio"
            "id": "65490326"
        "Google Chromecast": {
            "commands": [],
            "id": "65490322"
        "Philips Mini System": {
            "commands": [
                "PowerToggle",
                "Mute",
                "VolumeDown",
                "VolumeUp",
                "OK",
                "Stop",
                "Play",
                "Pause",
                "Menu",
                "Timer",
                "Program",
                "PresetPrev",
                "Scan",
                "PresetNext",
                "Sleep",
                "Info",
                "AlbumDown",
                "AlbumUp",
                "Clock",
                "Dim",
                "InputAudioIn/Usb",
                "InputBluetooth",
                "InputCd",
                "InputFm/Dab",
                "Mode",
                "Pairing",
                "Sound"
            "id": "65490324"
        "Samsung TV": {
            "commands": [
                "PowerOff",
                "PowerOn",
                "PowerToggle",
                "0",
                "1",
                "2",
                "3",
                "4",
                "5",
                "6",
                "7",
                "8",
                "9",
                "Mute",
                "VolumeDown",
                "VolumeUp",
                "ChannelPrev",
                "ChannelDown",
                "ChannelUp",
                "DirectionDown",
                "DirectionLeft",
                "DirectionRight",
                "DirectionUp",
                "Select",
                "Stop",
                "Play",
                "Rewind",
                "Pause",
                "FastForward",
                "Record",
                "Return",
                "Menu",
                "Subtitle",
                "Teletext",
                "C",
                "B",
                "D",
                "A",
                "Search",
                "Green",
                "Red",
                "Blue",
                "Yellow",
                "Guide",
                "Info",
                "Exit",
                "Aspect",
                "AD",
                "ChannelList",
                "DualI-II",
                "FamilyStory",
                "HDMI",
                "InputAv",
                "InputComponent",
                "InputExt",
                "InputHdmi1",
                "InputHdmi2",
                "InputHdmi3",
                "InputTv",
                "InputUsb",
                "SmartHub",
                "Source",
                "Support",
                "Tools"
            "id": "65490323"
        "arcadyan DVR": {
            "commands": [
                "PowerToggle",
                "0",
                "1",
                "2",
                "3",
                "4",
                "5",
                "6",
                "7",
                "8",
                "9",
                "ChannelPrev",
                "ChannelDown",
                "ChannelUp",
                "DirectionDown",
                "DirectionLeft",
                "DirectionRight",
                "DirectionUp",
                "Select",
                "Stop",
                "Play",
                "Rewind",
                "Pause",
                "FastForward",
                "Record",
                "Menu",
                "Teletext",
                "DVR",
                "Green",
                "Red",
                "Blue",
                "Yellow",
                "Guide",
                "Info",
                "Exit",
                "Radio",
                "TV"
            "id": "65490325"
As you see it contains the Samsung TV (as well KPN / XS4ALL tv receiver.
Make a scripts file that contains:
# Harmony
# Turn Activity Watch TV On
watch_tv_activity_on:
  alias: Start Watching TV
  sequence:
   - service: remote.turn_on
     entity_id: remote.living_room
       activity: 'Watch TV'
watch_tv_activity_off:
  alias: Stop Watching TV
  sequence:
   - service: remote.turn_off
# Samsung TV
tv_power_on:
  alias: On
  sequence:
  - service: remote.send_command
      command: PowerOn
      device: Samsung TV
tv_power_off:
  alias: Off
  sequence:
      command: PowerOff
      device: Samsung TV
tv_power_toggle:
  alias: On
  sequence:
      command: PowerToggle
      device: Samsung TV
tv_mute_audio:
  alias: Mute Audio
  sequence:
      command: Mute
      device: Samsung TV
tv_audio_volume_up:
  alias: Volume Up
  sequence:
      command: VolumeUp
      device: Samsung TV
tv_audio_volume_down:
  alias: Volume Down
  sequence:
      command: VolumeDown
      device: Samsung TV
tv_hdmi_1:
  alias: HDMI 1
  sequence:
      command: InputHdmi1
      device: Samsung TV
tv_hdmi_2:
  alias: HDMI 2
  sequence:
      command: InputHdmi2
      device: Samsung TV
tv_hdmi_3:
  alias: HDMI 3
  sequence:
      command: InputHdmi3
      device: Samsung TV
tv_input:
  alias: Digitenne
  sequence:
      command: InputTv
      device: Samsung TV
# DVB SetTop Box
dvb_power_toggle:
  alias: Power Toggle
  sequence:
      device: arcadyan DVR
dvb_menu:
  alias: Menu
  sequence:
      command: Menu
dvb_select:
  alias: Select
  sequence:
      command: Select
dvb_guide:
  alias: Guide
  sequence:
      command: Guide
dvb_left:
  alias: Left
  sequence:
      command: DirectionLeft
dvb_right:
  alias: Right
  sequence:
      command: DirectionRight
dvb_up:
  alias: Up
  sequence:
      command: DirectionUp
dvb_down:
  alias: Down
  sequence:
      command: DirectionDown
dvb_channel_up:
  alias: Channel Up
  sequence:
      command: ChannelUp
dvb_channel_down:
  alias: Channel Down
  sequence:
      command: ChannelDown
dvb_channel_prev:
  alias: Previous Channel
  sequence:
      command: ChannelPrev
dvb_number_1:
  alias: 1
  sequence:
      command: 1
dvb_number_2:
  alias: 2
  sequence:
      command: 2
dvb_number_3:
  alias: 3
  sequence:
      command: 3
dvb_number_4:
  alias: 4
  sequence:
      command: 4
dvb_number_5:
  alias: 5
  sequence:
      command: 5
dvb_number_6:
  alias: 6
  sequence:
      command: 6
dvb_number_7:
  alias: 7
  sequence:
      command: 7
dvb_number_8:
  alias: 8
  sequence:
      command: 8
dvb_number_9:
  alias: 9
  sequence:
      command: 9
dvb_radio:
  alias: Radio
  sequence:
      command: radio
dvb_number_0:
  alias: 0
  sequence:
      command: 0
dvb_tv:
  alias: TV
  sequence:
      command: tv
SInce I use the settop box, I left out the numeric of the Samsung TV, only needed HDMI.
Next make a custom card with data":
cards:
  - content: Samsung TV
    type: markdown
  - cards:
      - entity: script.tv_power_on
        icon: 'mdi:television'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.tv_power_off
        icon: 'mdi:power'
        tap_action:
          action: toggle
        type: entity-button
    type: horizontal-stack
  - cards:
      - entity: script.tv_audio_volume_down
        icon: 'mdi:volume-minus'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.tv_mute_audio
        icon: 'mdi:volume-mute'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.tv_audio_volume_up
        icon: 'mdi:volume-plus'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.tv_hdmi_1
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.tv_hdmi_2
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.tv_hdmi_3
        tap_action:
          action: toggle
        type: entity-button
type: vertical-stack
I did choose a vertical stack and your good to go.
Since this is a long post, this is the vertical stack of my KPN settop box…
cards:
  - content: KPN / XS4ALL
    type: markdown
  - cards:
      - entity: script.tv_power_toggle
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_power_toggle
        icon: 'mdi:power'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_menu
        icon: 'mdi:menu'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_select
        icon: 'mdi:check'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_guide
        icon: 'mdi:map-search'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_left
        icon: 'mdi:arrow-left'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_right
        icon: 'mdi:arrow-right'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_up
        icon: 'mdi:arrow-up'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_down
        icon: 'mdi:arrow-down'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_channel_up
        icon: 'mdi:minus'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_channel_prev
        icon: 'mdi:redo'
        tap_action:
          action: toggle
        type: entity-button
        icon: 'mdi:plus'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_number_1
        icon: 'mdi:numeric-1'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_2
        icon: 'mdi:numeric-2'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_3
        icon: 'mdi:numeric-3'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_number_4
        icon: 'mdi:numeric-4'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_5
        icon: 'mdi:numeric-5'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_6
        icon: 'mdi:numeric-6'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_number_7
        icon: 'mdi:numeric-7'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_8
        icon: 'mdi:numeric-8'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_9
        icon: 'mdi:numeric-9'
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: script.dvb_radio
        icon: 'mdi:radio'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_number_0
        icon: 'mdi:numeric-0'
        tap_action:
          action: toggle
        type: entity-button
      - entity: script.dvb_tv
        tap_action:
          action: toggle
        type: entity-button
Hope this helps you out.
Awesome, thank you !
I’ll have a play with my setup, I also use a settop box, so this helps a lot!
Merry Christmas !
