Is there a way to control the repeat speed of a command in the new Harmony component? I took a look in the harmony code and in the remote platform and don’t see any specific timing handling. Is that handled by HASS’ service handling?
I also took a look at the repeat settings inside the Harmony Hub application/controls.
Specifically: I’m looking for a good technique to raise the volume. With each simulated press taking a sec or two, it can take a long time to get from a vol of 15 to a vol of 50.
Would I be better off finding a way to handle this from within the Harmony config?
I am wondering the same. What is the best way to issue the volume command? Support is great if you need a single command like mute, but multiple steps of volume take too much time.
Locally on the Harmony remote, I also have “favourite” channels setup that also send a string on multiple commands when hitting the logo of the channel directly from the remote (exit and then the channel numbers made up of 3 digits - e.g. BBC FOUR HD “116”)
Is there a way of exposing the favourite channel from Harmony to HomeAssistant, triggering the numbers directly from the Harmony and not from HomeAssistant as separate commands, thus making the latency more bearable?
@Marcus_Brannon: Did you find a solution in the meantime? Would be great if you could post it here as I believe this is still relevant. Any way to define the “button press duration” for a home assistant / logitech harmony hub setup would be much appreciated.
