Harmony input_select
Can someone tell me why this doesnot work?
i try to turn the volume up from my tv and ter controle turn over the input_boolean switch.
this doesnot work!
- alias: "test:"
       platform: state
       entity_id: input_select.volume
       to: 'VolumeUp'
      - service: remote.turn_on
          entity_id: remote.harmony_barts_remote
          command: "VolumeUp"
          device: "67374347"
          entity_id: input_boolean.test_jan2
If i try it like this it works but whitout volume going up (clear)
- alias: "test:"
       platform: state
       to: 'VolumeUp'
my understand is the automation will only work when the input_select get change to “VolumeUp”
think you have to have a other action to change the input_select.volume to something else so that when you change it back to “VolumeUp” the automation will kick off again
Yes but first i need to get it to work before i can turn it off again.
This works !
  - alias: "totaal :"
       platform: state
       to: "VolumeUp"
      - service: remote.send_command
        data_template:
          device: 67374347
          command: VolumeUp
