Harmony integration removed?
What is the story here ? Is “switch platform” the same as “Integration” ?
If Harmony disappears, then what is the best alternative that works in HA ?
I don’t use it but according to this there should be a select entity you can use instead:
There is also some discussion in the release notes topic: 2023.12: Welcome home! - #24 by adorobis
Click the “Replies” link under that post.
Indeed. It is only that there won’t be switches for Harmony activities anymore. Select entity is the easiest way to turn on a specific activity, you can also call remote.turn_on service providing activity id.
The issue I have with this, is that if you use this on a button in your dashboard, it no longer indicates status by button color. I’ve tried it with both select and remote turn on. Is there an easy way to change the button color to indicate which activity is active?
Thanks!
