In attempting to reduce dramatically the “phantom” power usage around the home, my harmony hub is on a tasmota plug which I am considering turning off at times it us unlikely to be in use.
This does raise the possibility of the hub being turned off when I use my harmony companion or 950 remotes. If these remotes send out signals that can be picked up in other ways, I could wake up the hub by turning the plug on in an automation. My hub connects to the WiFi so not sure how the remotes interact.
Is it RF, bluetooth??
I have a RF hub and also pick up ble in home assistant.
It may even be that the remotes may be defined as devices in HA already, perhaps via ble, but I cannot see a recognisable name and have not proactively set up remotes myself. Any ideas?
