Harmony Template Switch Config Error
I am currently trying to set up a Harmony Template switch but getting the following config error that I can not figure out:
esting configuration at /home/homeassistant/.homeassistant
Failed config
switch:
- Invalid config for [switch]: required key not provided @ data[‘platform’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 90).
Here is the relevant config:
switch:
    switches:
      netflix:
        value_template: "{{ is_state_attr('remote.harmony_hub’, 'current_activity', ‘PowerOn’) }}"
        turn_on:
          service: remote.turn_on
          entity_id: remote.harmony_hub
            activity: “30338681”
        turn_off:
          service: remote.turn_off
            activity: "-1"
Thank you for your help in advance!
entity_id needs to be inside your data:
switch:
    switches:
      netflix:
        value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'PowerOn') }}"
        turn_on:
            activity: '30338681'
        turn_off:
            activity: "-1"
EDIT: Editing this because it wasn’t 100% correct.
Thank you so much, it works!
