I’m spying on this query from unifpoller dashboards:
SELECT last("rx_bytes-r") AS "Rx Rate", last("tx_bytes-r") AS "Tx Rate", last("num_new_alarms") AS "Alarms" FROM "subsystems" WHERE ("site_name" =~ /^$site$/ AND "subsystem" = 'wan') AND $timeFilter GROUP BY "status", "gw_name", "wan_ip"
Which gives this output:
So far I’ve gotten this made that doesn’t work:
- platform: influxdb
host: localhost
username: !secret ha-influx-user
password: !secret ha-influx-pw
queries:
- name: Unifi Download Speed
where: '"site_name" = ''default'' AND "subsystem" = ''wan'''
field: rx_bytes-r
measurement: 'Bs'
group_function: last
database: unifi
unit_of_measurement: 'Bs'
The error looks like this:
2020-05-11 17:52:48 ERROR (MainThread) [homeassistant.components.sensor] influxdb: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 322, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 472, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/homeassistant/homeassistant/components/influxdb/sensor.py", line 164, in update
self.data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/influxdb/sensor.py", line 203, in update
points = list(self.influx.query(self.query).get_points())
File "/usr/local/lib/python3.7/site-packages/influxdb/client.py", line 461, in query
in data.get('results', [])
File "/usr/local/lib/python3.7/site-packages/influxdb/client.py", line 460, in <listcomp>
for result
File "/usr/local/lib/python3.7/site-packages/influxdb/resultset.py", line 25, in __init__
raise InfluxDBClientError(self.error)
influxdb.exceptions.InfluxDBClientError: expected field argument in last()
So it says I should put an argument in last (), but didn’t I do that with the field ?
