Has anyone been able to get Honeycomb Menu from HACS working?
It’s quite possible the load order is not loaded correctly. Try a full hard reload (refresh cache etc). In regards to the look, see the theme examples on the readme.
So I was able to get this working relatively consistent. I was also able to get the honeycomb shape theme for the buttons. The only thing left I am trying to figure out is how to get my button card to also look like the honeycomb ?
Thanks,
Can you share a screenshot of what you want changed and the code you have at the moment ?
So I’m just trying to get the card itself to be honeycomb shaped (inside red square):
As for the code, I don’t have any. Wasn’t sure if this was some sort of change I need to make inside my theme.yaml file for my current Theme or what.
You cannot alter the shape of the custom button card.
Or I misunderstood your question perhaps ?
Could you share what it is that you would like it to look like ?
Yeah, this is from the Github for this integration. It looks as though the button cards themselves are honeycomb shaped, and then when clicked on, the honeycomb buttons open:
example-variables
Well I don’t think you will find that in any of the ‘examples’ because I don’t see it unless @Sian will share that with us?
But, don’t stress you can do your own.
Grab yourself a hexagon PNG.
I got it from here and modified it for an ON state as well just for some testing.
honey
hex_1
hex_1
Place these 2 files in config/www/images/ directory.
folder
Done.
Almost :wink:
Just a simple example to get you started.
Probably other ways of doing it better, but hey it works :thinking:
Paste this into a Manual card.
square: false
columns: 3
type: grid
cards:
  - type: custom:button-card
    entity: light.kitchen_3_lights
    entity_picture: /local/images/hex.png
    show_entity_picture: true
    state:
      - value: 'on'
        color: black
        entity_picture: /local/images/hex_1.png
      - value: 'off'
        color: black
        entity_picture: /local/images/honey.png
    styles:
      entity_picture:
        - width: 200%
        - height: 100%
      card:
        - filter: opacity(100%)
        - box-shadow: unset
        - background-color: unset
        - background: none
    tap_action:
      action: call-service
      service: honeycomb
      service_data:
        active: true
        buttons:
            tap_action:
              action: toggle
            entity: script.clean_living_room
            styles:
              icon:
                - color: violet
            position: 0
            tap_action:
              action: toggle
            entity: script.clean_bathroom
            styles:
              icon:
                - color: red
            position: 1
            tap_action:
              action: toggle
            entity: script.hallway
            styles:
              icon:
                - color: orange
            position: 2
            tap_action:
              action: toggle
            entity: script.clean_kitchen
            styles:
              icon:
                - color: green
            position: 3
            tap_action:
              action: toggle
            entity: script.clean_meals
            styles:
              icon:
                - color: aqua
            position: 4
            name: Go to Bin
            tap_action:
              action: toggle
            entity: script.goto_bin
            styles:
              icon:
                - color: white
            position: 5
    styles:
      entity_picture:
        - width: 200%
        - height: 100%
      card:
        - box-shadow: unset
        - background: none
    entity: light.kitchen_2_lights
    state:
      - value: 'on'
        color: black
      - value: 'off'
        color: black
    show_state: true
    styles:
      entity_picture:
        - width: 200%
        - height: 100%
      card:
        - box-shadow: unset
        - background: none
You should hopefully get something like this ?
test
Just an example of what’s possible. Do share how you go.
Take care my friend and all the best :+1:
try ensuring the following styles are in your current theme.yml:
--honeycomb-menu-icon-color: some color
--honeycomb-menu-icon-active-color: some color
--honeycomb-menu-background-color: some color
--honeycomb-menu-active-background-color: some color
--honeycomb-menu-disabled: some color
can anybody help me?
Logger: frontend.js.latest.202209070
Source: components/system_log/init.py:227
First occurred: 17:42:30 (1 occurrences)
Last logged: 17:42:30
webpack:///./src/honeycomb-menu.js?:347:16 Uncaught TypeError: Cannot read properties of undefined (reading ‘shade’)
This is likely do to incompatible web browser. I get that error if I try to use the honeycomb on my phone using the HA app. I can verify I have no issues in Chrome or Fully Kiosk Browser.
Tks @neofraz03 for the help. I tried several browsers, without success in all. Chrome, Edge, App HA, Brave…
hmm… I know that when I was having those issues, I rebooted my host machine running HASS, and then it started working better. I believe that @Sian said above that it seems something wasn’t loaded in the correct order, and a reboot resolved it for me. I also cleared my cache and cookies from my browser and relaunched it.
Can you share the code you have at the moment perhaps ?
tks @dexstar
It took several attempts until it worked. Thanks to all for your help
All good. Glad you go it working :+1:
hi friends i am triying to use HoneyComb menu over a Picture element.
I an doing something like:
type: custom:swipe-card
cards:
  - type: picture-elements
    elements:
        icon: mdi:lightbulb
        style:
          top: 25%
          left: 50%
          width: 5%
        tap_action:
          service: honeycomb
          service_data:
            active: true
            buttons:
                tap_action:
                  action: toggle
                entity: light.cocina_luz_barra
                styles:
                  icon:
                    - color: red
                position: 0
      - type: image
        entity: light.estancia01_habitacion1
        style:
          top: 61.5%
          left: 53%
          width: 31%
        state_image:
          'on': /local/floorplan/planta0HabJugON.png
          'off': /local/floorplan/transparent.png
        tap_action:
          action: toggle
      - type: image
        entity: light.bano01_banoabajo
        style:
          top: 56.5%
          left: 74%
          width: 24%
        state_image:
          'on': /local/floorplan/planta0banoOn.png
        tap_action:
          action: toggle
    image: /local/floorplan/planta0day_off.png
    elements:
      - type: state-icon
        entity: switch.jardin_riego_switch_1
        style:
          top: 10%
          left: 18.2%
          width: 24%
I have no problem with the images but the honeycomb menu dont show.
¿anyone know the reason?
Hi, there
recently I’ve integrated Honeycomb into my Home Assistant Dashboard (using a mix of standard lovelace cards and mushroom cards. Honeycomb works great using (even in Kiosk-Mode) on a Chrome browser. But with my mobile app I instantly get the message at the bootom of the screen:
error calling service honeycomb/undefined required key not provided @ data [‘service’]
Any helpful tips on how to resolve this?
I know according to GitHub this is still in Alpha Phase and errors are to expected, but maybe there is already a fix for that.
regards
I had the same issue and solution found above helped.
Instead of using
tap_action:
    action: more-info
use below:
tap_action:
    action: more-info
    tap_action: none
    hold_action: none
    double_tap_action: none
Where exactly should this go when I have themes from HACS installed? There’s no theme.yaml. I have
frontend:
  themes: !include_dir_merge_named themes
I use the Mushroom or Default theme.
Not sure where to put this and should I include or exclude styles{}?
styles {
    --honeycomb-menu-icon-color: var(--paper-item-icon-color);
    --honeycomb-menu-icon-active-color: var(--paper-item-icon-active-color);
    --honeycomb-menu-background-color: var(--paper-card-background-color);
    --honeycomb-menu-active-background-color: var(--paper-card-active-background-color, var(--paper-card-background-color));
	--honeycomb-menu-disabled: #9a9a9a6e;
If the menu is showing and you’re happy with the colours etc then just ignore it otherwise you might want to look at the themes documentation for Home Assistant
