I have just begun to learn HA and am hoping to access my UDI Polisy v5.8 system via this one. I can connect to the Polisy and I see the HA query all of my devices but the setup then seems to fail some available nodes in Home Assistant. Am I reading this correctly? Any ideas as to how to fix?
Here is my log:
2024-01-18 14:41:29.986 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.020 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.022 DEBUG (MainThread) [pyisy] ISY Request: http://192.168.1.72:8080/rest/config
2024-01-18 14:41:30.027 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.050 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.050 DEBUG (MainThread) [pyisy] Increasing available simultaneous connections
024-01-18 14:41:32.004 DEBUG (MainThread) [pyisy] Parsing group: S-All Dining Room [13825]
2024-01-18 14:41:32.005 DEBUG (MainThread) [pyisy] Parsing group: S-Dining Room [21083]
2024-01-18 14:41:32.006 DEBUG (MainThread) [pyisy] Parsing group: S-All-Office [338]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-H Special Lights Status [37129]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-C Kitchen Status [688]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-B Guest Rm Status [52360]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-1 Hall Status [27424]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-E Office Status [38353]
2024-01-18 14:41:32.009 DEBUG (MainThread) [pyisy] Parsing group: S-Christmas Lights [15887]
2024-01-18 14:41:32.009 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ISY (192.168.1.72) for isy994
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 406, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/isy994/init.py”, line 104, in async_setup_entry
await isy.initialize()
File “/usr/local/lib/python3.11/site-packages/pyisy/isy.py”, line 143, in initialize
self.nodes = Nodes(self, xml=isy_setup_results[2])
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 127, in init
self.parse(xml)
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 461, in parse
Group(
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 57, in init
self._update()
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 101, in _update
valid_nodes = [
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 105, in
self._nodes[node].status is not None
AttributeError: ‘Nodes’ object has no attribute ‘status’
