I’ve just ordered an Ikea Vallhorn motion sensor, with the intention of pairing it with my Sonoff Zigbee Bridge (flashed with Tasmota). I want to use it to trigger lighting in the hallway.
I was wondering whether anyone had any hints re. pairing/using it with the Sonoff Zigbee Bridge?
What coordinator software are you using?
If I understand you correctly, I believe that I’m using Zigbee2Tasmota (with MQTT to interact with HA)
Then this is a good place to look for immediate compatibility.
https://zigbee.blakadder.com/zigbee2tasmota.html
If your device is not there, this will give you more info:
Zigbee - Tasmota.
Thanks for the links.The Vallhorn isn’t on the compatibility list so I’ll have to cross my fingers and hope that I can pair it when it arrives…
I can confirm that the Vallhorn paired first time with the Sonoff Zigbee Bridge (running Tasmota). 4 button presses on the top Vallhorn button was enough, after I’d put the Bridge into “Permit Join” mode.
