It looks like the sensor is $7 right now and there is a 50% off applied at checkout.
$3.50 might be the cheapest motion sensor i’ve seen! So I have to ask, has anyone been able to use these with HA?
Figure anything out on this? $3.50 for a motion sensor was too good to pass up. I have two that have come in. I’m happy to rip one of these apart if that will help.
Edit: I’ll do one better. If you are interested in getting one of these working with HA, I’ll mail you one for free. Apparently it’s a ESP32-S0WD chip.
any updates on the sensors?
Nope. It may be a dead-end (i.e. the board is not flashable) or more likely just a case where not enough of the right/smart people got tricked into buying these cheap sensors.
Thanks, worth a shot.
Any recommendations on motion sensors with HA that are pet friendly and more affordable
Based off this it seems it would be using a HC-SR501 motion PIR sensor
I also have 2 of these sensors would love to flash them
Wait if it’s just an esp32 then we just need to flash it. Have you guys jumped on esphome discord and tried at all ? I love the idea these are cheap and disposable almost. I’ll grab a few when I finish my current project (1-2 more months ) and try to solder leads to flash it. Plenty of YouTube videos for how to flash with soldering terminals or using a jig to old the terminals to the chip
I cannot claim any expertise here but this version of the ESP32 was deemed unflashable in earlier discussions. That said, I don’t know that anyone has tried. See the link to the discussion above from Reddit. A Kangaroo rep even jumped in.
Note: The chip in the Kangaroo is mentioned in the Tasmota ESP32 specs: Features - Tasmota
Ok. Did a little sleuthing:
Here are photos from the FCC registry. This gives me some hope.
https://fccid.io/2APSE-MOTION1/Internal-Photos/Internal-Photos-3903605
I could find nothing on the Sputnik PIR board for the sensor. There are, however, a number of labeled pads as well as some unlabeled holes for header pins.
see we are otw we can doo iit lol
Under the law that “Nothing is easy,” the board has changed since its FCC approval. (We are now on “MOTION2” rather than “MOTION1.”) We no longer have any holes for pins and nothing is labeled on the board.
Good news: It would seem that the layout of the pads is the same as on the labeled MOTION1 version (i.e. they’re all in the same locations). As such we can assume the labels on MOTION1 are still our guide.
Bad news: I’m not the person with the skills/experience to solder this up and figure this out.
These are the photos of the board I just took:
Things I think I know:
Things I don’t know:
nice on the v1 labels! thats perfect! i think the next option would be to try to connect the solder leads. They might have the flashing button tied to the other chip to try and prevent it from being flashed. might need to scratch some off to solder to ground, and fake a switch as it were
None of the images are very high quality, so I can’t tell for sure, but that could be an SPI flash chip for storing data like the program. If it is, then it’s possible (failing all else) that you might be able to program an esp32/8266 developer board and move the flash chip over. I think I’ve seen enough to go get one myself. I’ll post back here if I have any success
