Converting slowly from Hubitat
I’m using the GoControl HUSBZB-1 USB Hub, have many Sengled Classic bulbs in use working perfectly with Hubitat. Even after flashing the HUSBZB-1 to the latest Silicon Labs (6.6.5) using https://github.com/walthowd/husbzb-firmware (worked perfectly) I cannot add my bulbs even after the 10 on/off reset.
Are they not able to be zigbee joined in Home Assistant with the HUSBZB-1? is it the HUSBZB-1 zigbee setup that if I got a different zigbee hub it would work? I don’t like not being able to re-use hardware that worked perfectly for years.
any tips? thanks in advance
