Has anyone used this switch? Its cheap so I was trying to figure out if It is compatible with a husbzb-1 hub and js node z wave?
I don’t think that this switch can switch a load (think light/outlet), it is GEs solution to a 3-way switch. This switch is combined with their 3-way switches to provide 3-way control to a load. This is basically a dummy switch to communicate with their z-wave 3-way switch.
Umm wat? Can it connect to z wave and be turned on and off? I’m using a home assistant hub that has z wave with Js node z wave
It says it does. So idk.
The description is pretty clear:
" Enbrighten Add-On Switch QuickFit and SimpleWire, In-Wall Toggle, Z-Wave ZigBee Wireless Smart Lighting Controls, NOT A STANDALONE Switch, 46200"
It only works in conjunction with a stand-alone Zwave or Zigbee switch.
I use Inovelli Z-Wave switches because they can be with existing 3-way or 4-way switches.
Umm someone in the reviews say it works with tbwir hub. U think not stand alone just means it’s not wifi and needs a hub?
That is a companion or add-on switch for a three-way setup. Requires this parent switch to work. That add-on will not pair directly to a hub/bridge.
You’ll need this one.
Do you know one that works and will pair with a home assistant in the same shape?
The one I linked above
