HAs Supervisor shows ~300/1000mb RAM usage but its' supposedly used up from trying to download a 30mb log file
Can someone explain this to me?
Supervisor memory usage:
out of memory error:
running a RPI 3B with 1GB of RAM btw
You are using bare minimum of memory and probably today this isn’t sufficient. I don’t say you can’t run it, but you will be probably facing this problem.
My home assistant installation in docker is using 1.7 GB or ram. And that is just one container out of 29.
You guys keep saying that but I don’t get the mechanism behind it and struggle to understand how much memory exactly I need if I can’t derive it from the readings in HAs’ superviser…
Memory is not that expensive. If you insist to run it on pi get at least 1 gb more.
How much memory you need it depends on what you gonna use it for. To run ha zigbbe and mqtt you dont need a lot.
But if you gonna have cameras codeproject.ai then you will need a lot more.
I tell people buy a used ddr3 based ram comp and use it for server. They are cheap memory for them are cheap you can get a diecent used gpu for it.
Jusr go for at least second gen intel cpu.
For running ha those comps are super powerfull but on the other hand very cheap to buy used.
The link shows a error 404 to me which indicates the file you are linking is not available.
Try attaching images directly to your post so that they are accessible for your audience!
The sensors will always be a view on the usage in the now and the past and there is no way to predict the future usage.
The view can only be used as a trend, but new and unknown things can never be accounted for and updates will practically always be new and unknown.
odd, I was able to open them
Whatever, I edited my start post
