tom_l
April 26, 2019, 4:43am
1
It only updates on a restart of HA then no further updates come in.
- platform: bom
station: IDT60901.94970
monitored_conditions:
- apparent_t
- gust_kt
- air_temp
- dewpt
- press
- rain_trace
- rel_hum
- wind_dir
- wind_spd_kt
tom_l
April 26, 2019, 8:56am
2
I can’t even use this to update it manually:
- id: weather_update
alias: 'Weather Update'
hide_entity: true
initial_state: true
- platform: time_pattern # Matches every hour at 10 minutes past whole
minutes: 10
- platform: time_pattern # Matches every hour at 40 minutes past whole
minutes: 40
service: homeassistant.update_entity
entity_id:
- sensor.bom_hobart_air_temp_c
- sensor.bom_hobart_dew_point_c
- sensor.bom_hobart_feels_like_c
- sensor.bom_hobart_pressure_mb
- sensor.bom_hobart_rain_today
- sensor.bom_hobart_relative_humidity
- sensor.bom_hobart_wind_direction
- sensor.bom_hobart_wind_gust_kt
- sensor.bom_hobart_wind_speed_kt
Checking the BoM website there are observations being added every 30 minutes.
tom_l
April 26, 2019, 1:57pm
3
Updating to 0.92 fixed the problem.
DrewXT
(Andrew)
May 10, 2019, 1:23am
4
I’m on 0.92.2 and still got bom.sensor errors… this is hugely descriptive error I get…
has anyone else seen and managed to resolve this - appeared around 0.91 from memory
my sensor config is:
platform: bom
station: IDV60901.94870
apparent_t
cloud
gust_kt
air_temp
dewpt
press
rain_trace
rel_hum
vis_km
weather
wind_dir
wind_spd_kt
tom_l
May 10, 2019, 4:13am
5
Have you updated to the new component?
You need this in your config as well as the sensor config.:
weather:
- platform: bom
Also please take note of points 3 and 11 in this: How to help us help you - or How to ask a good question
DrewXT
(Andrew)
May 15, 2019, 2:04pm
6
Thanks for that… Unfortunately it makes no difference. The documentation indicates the weather component is an alternative to the sensor, rather than a dependency.
On HASSIO it works, but not Hassbian, yet there are no documented dependencies that I can see
tom_l
May 15, 2019, 2:24pm
7
Yeah you’re right. That is not needed for the sensor.
That’s pretty specific. You should open an issue: https://github.com/home-assistant/home-assistant/issues?utf8=✓&q=is%3Aissue+is%3Aopen+bom
DrewXT
(Andrew)
May 17, 2019, 3:17am
8
I resolved my issue last night (in case anyone also has it) … when I delved deeper into my logs, I found that Pillow was trying to upgrade the bomradarloop module, and failing.
the resolution ended up being:
sudo aptitude install libtiff5-dev libjpeg8-dev zlib1g-dev libfreetype6-dev liblcms2-dev libwebp-dev libharfbuzz-dev libfribidi-dev tcl8.6-dev tk8.6-dev python-tk
then activating the python venv, and upgrading Pillow
source /srv/homeassistant/bin/activate
pip install Pillow
pip install bomradarloop
reboot, and voila - bom sensor working again
