cannot find the configuration file
Its location is described in the Technical details sections of the installation page
https://home-assistant.io/docs/installation/hassbian/installation/#technical-details
i found it there is two configuration.yaml.save and save.1,but they are both empty
Have you started homeassistant yet? The configuration file is normally created when you run the program and it can’t find it.
