During one of the updates CCH was replaced by new version and since than, I got empty HACS integration with nothing in it. CCH was functioning but with log errors.
How can I remove HACS manually and start over the HACS installation. There is no record of such an operation.
I can;t erase the HACS from the integration using the garbage can of the integration.
okay
its just a custom component
meaning what ever is in that folder is just that
you can delete the whole folder
download it again
and put back a fresh downloaded copy
all you need in you configuration.yaml is your hacs Personal Access token
(maybe that is your issue ?)
hacs:
token: !secret hacstoken
as i said before all the config file it uses are in the .storage folder
so if you delete them (only the HACS ones)
remove the custom component folder
re download the it again
confirm the token or get another one
check you configuration.yaml
check your config
reboot
you should be fine after it reinitializes itself
