Haskka test failed
This is what error I get any help appreciated
Test Event Name
Test
Response
“errorMessage”: “Unable to import module ‘lambda_function’: No module named ‘lambda_function’”,
“errorType”: “Runtime.ImportModuleError”,
“stackTrace”: []
Function Logs
START RequestId: a13eb075-73af-48f2-abd7-ccd5037e23f9 Version: $LATEST
[ERROR] Runtime.ImportModuleError: Unable to import module ‘lambda_function’: No module named ‘lambda_function’
END RequestId: a13eb075-73af-48f2-abd7-ccd5037e23f9
REPORT RequestId: a13eb075-73af-48f2-abd7-ccd5037e23f9 Duration: 1.84 ms Billed Duration: 2 ms Memory Size: 128 MB Max Memory Used: 36 MB Init Duration: 112.79 ms
Request ID
START RequestId: cf8668c6-acf2-4e0f-a5ca-55a97bccbbad Version: $LATEST
Traceback (most recent call last):END RequestId: cf8668c6-acf2-4e0f-a5ca-55a97bccbbad
REPORT RequestId: cf8668c6-acf2-4e0f-a5ca-55a97bccbbad Duration: 11.69 ms Billed Duration: 12 ms Memory Size: 128 MB Max Memory Used: 37 MB
I received the same error message and I was wondering if you can share if you fixed it and how?
I am not able to figure this one out.
I found a fix.
  1. go to aws console https://us-east-1.console.aws.amazon.com/lambda/home?region=us-east-1#/functions
  2. open your lambda function
  3. scroll down past the code editor, to Runtime settings, press edit.
  4. change the ‘handler’ to haaska.event_handler
  5. Save
re-test and hopefully it works for you as it did for me!
SCR-20230306-qbzv|690x357
