HASS addons stop working and supervisor is not responding
I have HASS ruuning for almost 2 years now (in a VM on x86) and for the past 4 days all addons (Frigate, SSH as an example) stop working at once and the supervisor is not responding. Restarting the supervisor brings it back but only for under 24 hours and then it happens again. The only change I made in the 4 days was upgrade Zwave JS and I restored an older version but it didn’t fix the problem. Here are some logs (can’t open the supervisor logs when it locks)
I am on 2022.8.6
Any help on where or what to look for ?
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:254
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 12:27:23 AM (2 occurrences)
Last logged: 12:27:23 AM
/ingress/validate_session return code 401
Logger: homeassistant.components.homeassistant_alerts
Source: helpers/update_coordinator.py:151
Integration: Home Assistant Alerts (documentation, issues)
First occurred: 4:54:00 AM (1 occurrences)
Last logged: 4:54:00 AM
Timeout fetching homeassistant_alerts data
Source: /usr/src/homeassistant/homeassistant/runner.py:96
First occurred: October 2, 2022 at 1:08:00 PM (2 occurrences)
Last logged: 6:00:03 AM
Error doing job: protocol.resume_writing() failed
File β€œ/usr/local/lib/python3.10/asyncio/transports.py”, line 300, in _maybe_resume_protocol
self._protocol.resume_writing()
File β€œ/usr/local/lib/python3.10/asyncio/sslproto.py”, line 522, in resume_writing
self._app_protocol.resume_writing()
File β€œ/usr/local/lib/python3.10/site-packages/aiohttp/base_protocol.py”, line 31, in resume_writing
assert self._paused
AssertionError
This error originated from a custom integration.
Logger: custom_components.hacs
Source: custom_components/hacs/base.py:503
Integration: HACS (documentation, issues)
First occurred: 4:54:10 AM (6 occurrences)
Last logged: 8:54:10 AM
Timeout of 20 reached while waiting for https://api.github.com/rate_limit
File β€œ/config/custom_components/hacs/base.py”, line 449, in async_can_update
response = await self.async_github_api_method(self.githubapi.rate_limit)
File β€œ/config/custom_components/hacs/base.py”, line 503, in async_github_api_method
raise HacsException(_exception)
custom_components.hacs.exceptions.HacsException: Timeout of 20 reached while waiting for https://api.github.com/rate_limit
Source: custom_components/hacs/utils/queue_manager.py:71
First occurred: 5:26:05 AM (13 occurrences)
Last logged: 9:06:05 AM
Timeout of 20 reached while waiting for https://api.github.com/repos/jaruba/ha-samsungtv-tizen/contents/custom_components/samsungtv_tizen/manifest.json
Timeout of 20 reached while waiting for https://api.github.com/repos/bruxy70/Garbage-Collection/contents/custom_components/garbage_collection/manifest.json
Timeout of 20 reached while waiting for https://api.github.com/repos/ollo69/ha-smartthinq-sensors/contents/custom_components/smartthinq_sensors/manifest.json
Timeout of 20 reached while waiting for https://api.github.com/repos/elad-bar/ha-hpprinter/contents/custom_components/hpprinter/manifest.json
Source: helpers/update_coordinator.py:237
First occurred: 3:32:50 AM (5 occurrences)
Last logged: 9:20:55 AM
Error fetching hassio data: Error on Supervisor API:
Today I was able to get these errors from the supervisor. Restarting the supervisor from the console (supervisor reload) fixes the problem
22-11-14 16:44:38 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:5000 ssl:default [Connect call failed (β€˜172.30.33.4’, 5000)]
22-11-14 16:44:38 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name=β€˜Task-39964’ coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:982> exception=AddonsJobError(β€˜Rate limit exceeded, more then 10 calls in 0:30:00’)>
File β€œ/usr/src/supervisor/supervisor/addons/addon.py”, line 996, in watchdog_container
await self._restart_after_problem(self, event.state)
File β€œ/usr/src/supervisor/supervisor/jobs/decorator.py”, line 144, in wrapper
raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more then 10 calls in 0:30:00
22-11-14 16:44:39 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:5000 ssl:default [Connect call failed (β€˜172.30.33.4’, 5000)]
22-11-14 16:46:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-11-14 16:46:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-11-14 16:46:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
Any resolution to this ? I’m seeing exactly the same thing. And restarting supervisor works.
In fact, it got so frustrating that I broke out my second NUC and put plain vanilla Debian 10 on it with no Portainer, just straight docker. Same thing, supervisor just stops responding after about 24 hours.
Of course, I’m on all the latest versions of everything.
Very frustrating…
Unfortunately no, it happens randomly in my case
I seem to be having similar issues. The weather entity, MY Q and Airthings, Ad guard and a couple of other entities become unavailable. I am running HA on a dedicated Dell laptop. Re-starting HA OS solves the problem for 2 hours then the same thing. I tried HA commands – HA core rebuild and HA supervisor repair. That too fixes the problem but only for a couple of hours. Supervisor is unresponsive.
Any help would be appreciated
2023-01-14 11:04:27.351 WARNING (Thread-110) [pychromecast.socket_client] [Family Room TV(192.168.88.78):8009] Heartbeat timeout, resetting connection
2023-01-14 11:04:34.451 ERROR (Thread-110) [pychromecast.socket_client] [Family Room TV(192.168.88.78):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.88.78', 8009)), retrying in 5.0s
2023-01-14 11:07:42.959 WARNING (Thread-110) [pychromecast.socket_client] [Family Room TV(192.168.88.78):8009] Heartbeat timeout, resetting connection
2023-01-14 11:08:12.996 ERROR (Thread-110) [pychromecast.socket_client] [Family Room TV(192.168.88.78):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.88.78', 8009)), retrying in 5.0s
2023-01-14 11:50:04.796 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/5c53de3b_esphome/stats request
2023-01-14 11:50:04.801 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 5c53de3b_esphome:
2023-01-14 11:50:04.804 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nut/stats request
2023-01-14 11:50:04.806 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nut:
2023-01-14 11:50:04.808 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_plex/stats request
2023-01-14 11:50:04.809 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_plex:
2023-01-14 11:50:04.811 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2023-01-14 11:50:04.813 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2023-01-14 11:50:04.815 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/75a80a57_rtsp_simple_server/stats request
2023-01-14 11:50:04.817 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 75a80a57_rtsp_simple_server:
2023-01-14 11:53:38.717 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esp-cold-room @ 192.168.88.79: Hello timed out
2023-01-14 11:54:40.397 WARNING (MainThread) [homeassistant.components.esphome] Error getting initial data for 192.168.88.79: Timeout waiting for response for <class 'api_pb2.DeviceInfoRequest'> after 10.0s
2023-01-14 11:54:59.182 ERROR (MainThread) [homeassistant.components.roku.coordinator] Error fetching roku data: Invalid response from API: Timeout occurred while connecting to device
2023-01-14 11:55:14.798 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/75a80a57_rtsp_simple_server/stats request
2023-01-14 11:55:14.800 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 75a80a57_rtsp_simple_server:
2023-01-14 11:55:14.803 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-01-14 11:55:14.805 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 45df7312_zigbee2mqtt:
2023-01-14 11:55:14.807 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/5c53de3b_esphome/stats request
2023-01-14 11:55:14.808 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 5c53de3b_esphome:
2023-01-14 11:55:14.810 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_adguard/stats request
2023-01-14 11:55:14.812 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_adguard:
2023-01-14 11:55:14.814 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_nginx_proxy/stats request
2023-01-14 11:55:14.818 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_nginx_proxy:
2023-01-14 11:55:14.820 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nut/stats request
2023-01-14 11:55:14.822 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nut:
2023-01-14 11:55:14.824 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2023-01-14 11:55:14.826 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2023-01-14 11:55:14.828 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_plex/stats request
2023-01-14 11:55:14.830 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_plex:
2023-01-14 11:55:37.276 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:55:57.183 ERROR (MainThread) [homeassistant.components.roku.coordinator] Error fetching roku data: Invalid response from API: Timeout occurred while connecting to device
2023-01-14 11:55:57.278 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:55:57.280 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 11:56:07.279 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:56:07.284 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 11:56:17.280 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:56:17.289 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 11:56:27.281 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:56:27.294 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 11:56:37.283 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:56:37.297 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 11:56:57.285 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:56:57.287 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 11:57:06.079 ERROR (MainThread) [custom_components.tplink_deco] Timeout fetching tplink_deco-clients data
2023-01-14 11:57:07.198 ERROR (MainThread) [custom_components.tplink_deco] Timeout fetching tplink_deco-decos data
2023-01-14 11:57:07.286 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:57:07.290 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 11:57:17.287 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:57:17.295 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 11:57:27.288 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:57:27.299 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 11:57:37.292 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:57:37.303 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 11:57:57.293 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:57:57.295 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 11:58:07.293 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:58:07.299 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 11:58:09.796 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2023-01-14 11:58:09.798 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2023-01-14 11:58:09.800 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2023-01-14 11:58:09.802 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2023-01-14 11:58:09.804 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2023-01-14 11:58:09.806 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2023-01-14 11:58:09.808 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2023-01-14 11:58:17.294 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:58:17.303 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 11:58:24.588 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_dns_queries is taking over 10 seconds
2023-01-14 11:58:24.590 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_safe_browsing_blocked is taking over 10 seconds
2023-01-14 11:58:24.591 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_dns_queries_blocked_ratio is taking over 10 seconds
2023-01-14 11:58:24.593 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_parental_control_blocked is taking over 10 seconds
2023-01-14 11:58:27.296 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:58:27.305 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 11:58:34.597 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_safe_searches_enforced is taking over 10 seconds
2023-01-14 11:58:34.604 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_average_processing_speed is taking over 10 seconds
2023-01-14 11:58:37.297 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:58:37.310 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 11:58:57.298 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:58:57.301 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 11:59:07.300 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:59:07.304 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 11:59:17.300 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:59:17.308 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 11:59:27.301 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:59:27.312 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 11:59:37.304 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:59:37.316 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 11:59:51.796 ERROR (MainThread) [homeassistant.components.life360] Error fetching life360 ([email protected]) data: TimeoutError
2023-01-14 11:59:54.199 ERROR (MainThread) [airthings] Timed out when connecting to Airthings for token
2023-01-14 11:59:54.204 ERROR (MainThread) [homeassistant.components.airthings] Error fetching airthings data: Unable to fetch data:
2023-01-14 11:59:57.305 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 11:59:57.308 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:00:07.307 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:00:07.311 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:00:17.308 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:00:17.316 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:00:25.797 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2023-01-14 12:00:25.799 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2023-01-14 12:00:25.801 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2023-01-14 12:00:25.803 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2023-01-14 12:00:25.805 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API:
2023-01-14 12:00:27.308 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:00:27.319 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:00:37.309 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:00:37.323 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:00:57.311 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:00:57.313 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:01:07.312 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:01:07.316 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:01:17.313 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:01:17.319 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:01:27.314 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:01:27.323 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:01:37.316 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:01:37.326 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:01:57.318 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:01:57.321 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:02:07.319 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:02:07.324 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:02:17.320 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:02:17.328 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:02:27.321 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:02:27.332 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:02:37.322 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:02:37.335 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:02:57.323 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:02:57.326 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:03:03.796 ERROR (MainThread) [homeassistant.components.myq] Timeout fetching myq devices data
2023-01-14 12:03:07.324 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:03:07.329 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:03:17.325 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:03:17.332 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:03:20.796 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2023-01-14 12:03:20.799 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2023-01-14 12:03:20.801 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2023-01-14 12:03:20.803 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2023-01-14 12:03:20.805 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2023-01-14 12:03:20.807 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2023-01-14 12:03:20.809 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2023-01-14 12:03:24.589 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_dns_queries is taking over 10 seconds
2023-01-14 12:03:24.591 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_safe_browsing_blocked is taking over 10 seconds
2023-01-14 12:03:24.593 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_dns_queries_blocked_ratio is taking over 10 seconds
2023-01-14 12:03:24.595 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_parental_control_blocked is taking over 10 seconds
2023-01-14 12:03:27.325 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:03:27.336 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:03:34.599 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_safe_searches_enforced is taking over 10 seconds
2023-01-14 12:03:34.602 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.adguard_average_processing_speed is taking over 10 seconds
2023-01-14 12:03:37.326 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:03:37.340 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:03:57.329 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:03:57.329 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:04:07.330 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:04:07.333 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:04:17.331 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:04:17.337 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:04:27.332 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:04:27.340 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:04:37.334 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:04:37.342 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:04:57.337 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:04:57.339 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:05:07.338 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:05:07.343 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:05:17.339 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:05:17.346 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:05:27.339 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:05:27.350 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:05:35.796 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2023-01-14 12:05:35.798 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2023-01-14 12:05:35.800 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2023-01-14 12:05:35.802 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2023-01-14 12:05:37.340 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:05:37.354 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_filtering is taking over 10 seconds
2023-01-14 12:05:57.342 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:05:57.345 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_protection is taking over 10 seconds
2023-01-14 12:06:07.343 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:06:07.348 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_parental_control is taking over 10 seconds
2023-01-14 12:06:17.345 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:06:17.353 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_search is taking over 10 seconds
2023-01-14 12:06:27.346 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2023-01-14 12:06:27.357 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.adguard_safe_browsing is taking over 10 seconds
2023-01-14 12:06:34.199 ERROR (MainThread) [airthings] Timed out when connecting to Airthings for token
In the last 48 hours after restoring home assistant and all addons to a previous backup from December 2022, my HA seems to be stable. However in Node Red all triggers are showing disconnected. I will apply updates in HA one by one and then see which update is causing the problems.
