A strange combination of HA MQTT integration and HASS.Agent MQTT broker connections:
Here’s the situation:
HA MQTT Integration can connect to my local MQTT Broker via it’s 172…-IP address only, but not via it’s 192…-IP address.
Testing with MQTTX confirm both IP addresses work equally elsewhere.
HASS.Agent MQTT configuration can’t connect to either of those IP addressess (yes, the port is correct and opened), it only connects succesfully when using ‘localhost’ as broker.
While having the above mentioned (working) options selected on both, everything is seemingly connected.
However almost nothing sent via MQTT works between these two things (HA and HASS.Agent), EXCEPT sending defined HA sensor commands from HASS.Agent to HA, those work perfectly every time. So HASS.Agent to HA direction seems to work, but only for commands
Nothing from HA can be sent to HASS.Agent host, and nothing defined in HASS.Agent is autodiscovered on HA side.
What could be the cause of this, the logs show nothing? HASS.Agent logs show everything connected. HA shows no errors. Yet, information is not flowing.
