I've been beating my head against the wall over this for the last couple of days and finally discovered why I was unable to get TTS announcements on my main PC through Hass.Agent. Full disclosure, Claude AI was a big help in determining why my TTS actions were executing successfully in HA, but with no results. Since there is no place on the HASS.Agent Github to post the issue, I guess the correct spot is on this forum? Here is the summary of the issue:
- Windows.Media.Playback uses WASAPI shared mode
- When default audio format is set to "Dolby Atmos for Home Theater", WASAPI shared mode cannot mix standard PCM audio, resulting in completely silent playback
- State correctly reports Playing → Paused with correct duration, giving no indication of failure
- Workaround: changing default format to standard PCM (e.g. 24-bit 48000 Hz) restores audio
- Fix suggestion: HASS.Agent should initialize audio using WASAPI exclusive mode or a spatial audio-aware rendering path.
Thanks.
EDIT: My mistake, it seems I was looking at the wrong Github page (The Hass.Agent situation seems a little confusing). I will post on the Github but leave this here in case it's useful to anyone else or someone has a suggestion.
