Trying to update core and get the following error:
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:109
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 7:22:56 PM (1 occurrences)
Last logged: 7:22:56 PM
Failed to to call /core/update - 'HomeAssistantCore.update' blocked from execution, system is not healthy
The issue it says I have is:
“You are running an unsupported installation, please check the list of issues found with your installation” and provides a link which takes me to: Network Manager - Home Assistant
What other info can I provide? This is a VM image I deployed and has been working quite well for a very long time.
No amount of reloads or checks worked. After some CLI work to try and update the supervisor or the core, it got to a point where it wouldn’t fully boot and was completely hosed.
It’s so hosed I can’t log in to grab the backup. I still have the image if anyone knows where the backups are located in that image, it would be appreciated
You are running hassio on RPI? Also, it seems that supervisor got a problem with some docker containers. Did you install any container that can cause this? Maybe watchtower?
