Hello, i switch my system from fibaro to hass and i have some problems witch pairing device. All wall switchs from Neo cool cam i paired without problems, but witch fibaro dimmer 2 FGD-212 and RGBW controllers FGRGBWM-441 i cant pair it. I activated add node mod on Hass and three-time click on button on fibaro, but system cant found new device Still “Controller nothing to do”. I using Z-wawe integration.
Thanks for any help
2020-07-06 12:34:14.911 Info, Node015, Received a MultiChannelEncap from node 15, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-07-06 12:34:14.911 Info, Node015, Received SwitchBinary report from node 15: level=Off
2020-07-06 12:34:14.911 Detail, Node015, Initial read of value
2020-07-06 12:34:14.911 Detail, Node015, Expected reply and command class was received
2020-07-06 12:34:14.911 Detail, Node015, Message transaction complete
2020-07-06 12:34:14.911 Detail, Node015, Removing current message
2020-07-06 12:34:14.911 Detail, Node015, Notification: ValueChanged
2020-07-06 12:34:14.920 Detail,
2020-07-06 12:34:14.920 Info, Node015, Sending (Send) message (Callback ID=0xaf, Expected Reply=0x04) - MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=15): 0x01, 0x0d, 0x00, 0x13, 0x0f, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0xaf, 0x2b
2020-07-06 12:34:14.930 Detail, Node015, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-07-06 12:34:14.930 Detail, Node015, ZW_SEND_DATA delivered to Z-Wave stack
2020-07-06 12:34:14.951 Detail, Node015, Received: 0x01, 0x18, 0x00, 0x13, 0xaf, 0x00, 0x00, 0x03, 0x00, 0xd8, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x81
2020-07-06 12:34:14.951 Detail, Node015, ZW_SEND_DATA Request with callback ID 0xaf received (expected 0xaf)
2020-07-06 12:34:14.952 Info, Node015, Request RTT 31 Average Request RTT 30
2020-07-06 12:34:14.952 Detail, Expected callbackId was received
2020-07-06 12:34:14.965 Detail, Node015, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x0f, 0x07, 0x60, 0x0d, 0x02, 0x01, 0x25, 0x03, 0x00, 0xd8, 0x00, 0x6c
2020-07-06 12:34:14.965 Info, Node015, Response RTT 44 Average Response RTT 43
2020-07-06 12:34:14.965 Info, Node015, Received a MultiChannelEncap from node 15, endpoint 2 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-07-06 12:34:14.965 Info, Node015, Received SwitchBinary report from node 15: level=Off
2020-07-06 12:34:14.965 Detail, Node015, Initial read of value
2020-07-06 12:34:14.965 Detail, Node015, Expected reply and command class was received
2020-07-06 12:34:14.965 Detail, Node015, Message transaction complete
2020-07-06 12:34:14.965 Detail, Node015, Removing current message
2020-07-06 12:34:14.965 Detail, Node015, Notification: ValueChanged
2020-07-06 12:34:14.973 Detail, Node015, Query Stage Complete (Dynamic)
2020-07-06 12:34:14.973 Detail, Node015, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-07-06 12:34:14.973 Detail, Node015, QueryStage_Configuration
2020-07-06 12:34:14.973 Detail, Node015, QueryStage_Complete
2020-07-06 12:34:14.973 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2020-07-06 12:34:14.974 Detail, Node015, Notification: NodeQueriesComplete
2020-07-06 12:37:15.317 Detail, Queuing (Controller) Add Device
2020-07-06 12:37:15.317 Info, Add Device
2020-07-06 12:37:15.317 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0xb0, 0xc1
2020-07-06 12:37:15.317 Detail, Notification: ControllerCommand - Starting
2020-07-06 12:37:15.319 Detail,
2020-07-06 12:37:15.320 Info, contrlr, Sending (Command) message (Callback ID=0xb0, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0xb0, 0xc1
2020-07-06 12:37:15.329 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0xb0, 0x01, 0x00, 0x00, 0x03
2020-07-06 12:37:15.329 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-07-06 12:37:15.329 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-07-06 12:37:15.329 Detail, Node001, Expected callbackId was received
2020-07-06 12:37:15.329 Detail, Node001, Expected reply was received
2020-07-06 12:37:15.329 Detail, Node001, Message transaction complete
2020-07-06 12:37:15.329 Detail, contrlr, Removing current message
2020-07-06 12:37:15.330 Detail, Notification: ControllerCommand - Waiting
2020-07-06 12:37:15.334 Info, WriteNextMsg Controller nothing to do
