I’ve managed to actually get some logs out of the system when this problem occurred. I had this issue for a long time, but this time I decided to get some logs etc.
So my problem is that after a system upgrade (today upgraded to 2024.5.4) the hass can’t get anything from Mosquito (I can wait even half an hour, with not effect). If I reload Mosquito broker - seems to fix the problem.
I’ve tested whenever a simple reboot can cause the same issue - but seems to not.
Here goes events.
Life goes as normal:
2024-05-17 18:27:18: New connection from 172.30.32.2:34946 on port 1883.
2024-05-17 18:27:18: Client <unknown> closed its connection.
2024-05-17 18:29:18: New connection from 172.30.32.2:42888 on port 1883.
2024-05-17 18:29:18: Client <unknown> closed its connection.
2024-05-17 18:31:18: New connection from 172.30.32.2:40758 on port 1883.
2024-05-17 18:31:18: Client <unknown> closed its connection.
2024-05-17 18:33:18: New connection from 172.30.32.2:34960 on port 1883.
2024-05-17 18:33:18: Client <unknown> closed its connection.
2024-05-17 18:35:18: New connection from 172.30.32.2:47782 on port 1883.
2024-05-17 18:35:18: Client <unknown> closed its connection.
2024-05-17 18:37:18: New connection from 172.30.32.2:41016 on port 1883.
2024-05-17 18:37:18: Client <unknown> closed its connection.
2024-05-17 18:39:18: New connection from 172.30.32.2:34172 on port 1883.
2024-05-17 18:39:18: Client <unknown> closed its connection.
2024-05-17 18:41:18: New connection from 172.30.32.2:57810 on port 1883.
2024-05-17 18:41:18: Client <unknown> closed its connection.
2024-05-17 18:43:18: New connection from 172.30.32.2:43650 on port 1883.
2024-05-17 18:43:18: Client <unknown> closed its connection.
Performing an upgrade about here:
2024-05-17 18:45:14: Client 0P4JAKn3X0TuxGouQh3L1T closed its connection.
2024-05-17 18:45:18: New connection from 172.30.32.2:56482 on port 1883.
2024-05-17 18:45:18: Client <unknown> closed its connection.
After an upgrade this show up:
2024-05-17 18:45:23: New connection from 172.30.32.1:37163 on port 1883.
2024-05-17 18:45:23: New client connected from 172.30.32.1:37163 as 776MRYuMXaPB1JDQMYJF7t (p2, c1, k60, u'homeassistant').
2024-05-17 18:45:23: Outgoing messages are being dropped for client 776MRYuMXaPB1JDQMYJF7t.
At this point everything related to Z2M inside of HASS is “unknown”, while Z2M works perfectly fine. So I decided to perform a Mosquito plugin reload:
2024-05-17 18:47:10: New connection from 172.30.32.1:43891 on port 1883.
2024-05-17 18:47:10: New client connected from 172.30.32.1:43891 as 3TfHo1uZGSUZ9PiORppUmj (p2, c1, k60, u'homeassistant').
2024-05-17 18:47:18: New connection from 172.30.32.2:48274 on port 1883.
2024-05-17 18:47:18: Client <unknown> closed its connection.
2024-05-17 18:48:41: Client 776MRYuMXaPB1JDQMYJF7t has exceeded timeout, disconnecting.
2024-05-17 18:49:18: New connection from 172.30.32.2:37234 on port 1883.
2024-05-17 18:49:18: Client <unknown> closed its connection.
Here I though “Hey, maybe I should try whenever on simple inside of HASS reboot I’ll be able to replicate this” - so I did the reboot.
2024-05-17 18:50:32: Client 3TfHo1uZGSUZ9PiORppUmj closed its connection.
2024-05-17 18:50:38: New connection from 172.30.32.1:60363 on port 1883.
2024-05-17 18:50:38: New client connected from 172.30.32.1:60363 as 3cfGlRCCZMfwrgaiRW90LL (p2, c1, k60, u'homeassistant').
2024-05-17 18:51:18: New connection from 172.30.32.2:54866 on port 1883.
2024-05-17 18:51:18: Client <unknown> closed its connection.
2024-05-17 18:53:18: New connection from 172.30.32.2:51798 on port 1883.
2024-05-17 18:53:18: Client <unknown> closed its connection.
And everything works just perfectly fine … so a reboot =!= upgrade in terms of results.
At this point nothing related to Z2M inside of HASS is “unknown”, while Z2M works perfectly fine. So I decided to perform a Mosquito plugin reload:
