/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/hdr_metadata.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/hdr_metadata.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/video_content_type.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/video_content_type.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/video_timing.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/api/video/video_timing.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/audio_converter.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/audio_converter.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/audio_util.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/audio_util.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/channel_buffer.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/channel_buffer.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_c.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_c.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_factory.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_factory.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -DVERSION_INFO=1.2.3 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1 -I/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/subprojects/abseil-cpp-20230125.1 -I/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/pybind11/include -I/srv/homeassistant/include -I/usr/local/include/python3.12 -c -std=c++17 /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc -o build/temp.linux-aarch64-cpython-312/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.o -fvisibility=hidden -g0 -DWEBRTC_LIBRARY_IMPL -DWEBRTC_ENABLE_SYMBOL_EXPORT -DNDEBUG -DWEBRTC_APM_DEBUG_DUMP=0 -D_GNU_SOURCE -DWEBRTC_LINUX -DWEBRTC_THREAD_RR -DWEBRTC_POSIX -DWEBRTC_ARCH_LITTLE_ENDIAN -DWEBRTC_ARCH_ARM64 -DWEBRTC_ARCH_ARM_FAMILY -DWEBRTC_ARCH_64_BITS -DWEBRTC_HAS_NEON
In file included from /tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:13:
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h: In member function ‘virtual void webrtc::FIRFilterNEON::Filter(const float*, size_t, float*)’:
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:6898:1: error: inlining failed in call to ‘always_inline’ ‘float32x4_t vmovq_n_f32(float32_t)’: target specific option mismatch
6898 | vmovq_n_f32 (float32_t __a)
/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:57:36: note: called from here
57 | float32x4_t m_sum = vmovq_n_f32(0);
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:1481:1: error: inlining failed in call to ‘always_inline’ ‘float32x4_t vmlaq_f32(float32x4_t, float32x4_t, float32x4_t)’: target specific option mismatch
1481 | vmlaq_f32 (float32x4_t __a, float32x4_t __b, float32x4_t __c)
/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:62:24: note: called from here
62 | m_sum = vmlaq_f32(m_sum, m_in, vld1q_f32(coef_ptr + j));
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:10396:1: error: inlining failed in call to ‘always_inline’ ‘float32x4_t vld1q_f32(const float32_t*)’: target specific option mismatch
10396 | vld1q_f32 (const float32_t * __a)
/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:61:23: note: called from here
61 | m_in = vld1q_f32(in_ptr + j);
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:6171:1: error: inlining failed in call to ‘always_inline’ ‘float32_t vget_lane_f32(float32x2_t, int)’: target specific option mismatch
6171 | vget_lane_f32 (float32x2_t __a, const int __b)
/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:66:27: note: called from here
66 | out[i] = vget_lane_f32(vpadd_f32(m_half, m_half), 0);
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:3547:1: error: inlining failed in call to ‘always_inline’ ‘float32x2_t vpadd_f32(float32x2_t, float32x2_t)’: target specific option mismatch
3547 | vpadd_f32 (float32x2_t __a, float32x2_t __b)
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:552:1: error: inlining failed in call to ‘always_inline’ ‘float32x2_t vadd_f32(float32x2_t, float32x2_t)’: target specific option mismatch
552 | vadd_f32 (float32x2_t __a, float32x2_t __b)
/tmp/pip-install-bl3d3wsu/webrtc-noise-gain_e57f3e667e8d499cb6d6f04cdb7875c7/webrtc-audio-processing/webrtc-audio-processing-1/common_audio/fir_filter_neon.cc:65:34: note: called from here
65 | float32x2_t m_half = vadd_f32(vget_high_f32(m_sum), vget_low_f32(m_sum));
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:7350:1: error: inlining failed in call to ‘always_inline’ ‘float32x2_t vget_low_f32(float32x4_t)’: target specific option mismatch
7350 | vget_low_f32 (float32x4_t __a)
/usr/lib/gcc/arm-linux-gnueabihf/10/include/arm_neon.h:7271:1: error: inlining failed in call to ‘always_inline’ ‘float32x2_t vget_high_f32(float32x4_t)’: target specific option mismatch
7271 | vget_high_f32 (float32x4_t __a)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/unixccompiler.py", line 185, in _compile
self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/ccompiler.py", line 1041, in spawn
spawn(cmd, dry_run=self.dry_run, **kwargs)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
raise DistutilsExecError(
setuptools._distutils.errors.DistutilsExecError: command '/usr/bin/gcc' failed with exit code 1
File "/srv/homeassistant/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/srv/homeassistant/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/srv/homeassistant/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 404, in build_wheel
return self._build_with_temp_dir(
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 389, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 480, in run_setup
super(_BuildMetaLegacyBackend, self).run_setup(setup_script=setup_script)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 311, in run_setup
exec(code, locals())
File "<string>", line 563, in <module>
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 103, in setup
return distutils.core.setup(**attrs)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 963, in run_command
super().run_command(command)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-92oonz6b/normal/lib/python3.12/site-packages/wheel/bdist_wheel.py", line 368, in run
self.run_command("build")
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build.py", line 131, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 88, in run
_build_ext.run(self)
File "/tmp/pip-build-env-92oonz6b/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
self.build_extensions()
File "<string>", line 511, in build_extensions
