Hass difficulty
Hi all,
I recently installed Home Assistant by writing the image on a Raspberry Pi 4 and its working well.
I installed SSH and when I try to run hass, i have been unable to. Specifically I would like to run ‘hass --script check_config’ to check a my configuration script but I get - ‘bash: hass: command not found’
When I go to the /srv directory it is empty so I am unable to set the hass directory. I tried searching for hass, but it is not found.
Googling revealed information about activating the virtual environment using ‘source /srv/hass/hass_venv/bin/activate’. That gives ‘No such file or directory’.
I am at a loss as to what I am doing wrong.
David
That statement implies you used the Home Assistant OS installation method
That information is for the Home Assistant Core installation method.
Based on the information in this link, can you let me know which installation method you used? It’s possible that you installed it one way (Home Assistant OS) but attempting to follow instructions intended for another way (Home Assistant Core).
I used the Home Assistant OS installation method.
Thank you,
David
Then none of the commands you mentioned apply to it. They are for Home Assistant Core.
If you want to check the configuration via the command-line, you can use this:
ha core check
The configuration files are in:
/config
Thanks for the help!
David
You’re welcome!
As a courtesy for other users, who may have a similar question, please mark my previous post with the Solution tag. This will automatically place a check-mark next to the topic’s title which signals to other people that this topic has an accepted solution.
