HASS does not boot up anymore component XXX took longer then expected
Hass.io take like 30min to startup at first install. (I think it download additional items). Long download time could cause issue for your new install.
RE: giving up on HA
Possible your original problem was “too big log file”? I have had issue where she card fill.with log and HASS crash and not able to access. I moved to 8core server from pi and I think more stable overall. Also I think docker install is better experience since only take 30second to have fully functional HA instance. RasPI OK but read/writes on sdcard can cause issue long term (just read sdcard I have seen Pi work years with other software) there are ways to mitigate these issues but this require planning
not the first install, that went well. The further boots
I made a fresh installation, no logs
I run hassio logs
I receive this
17-10-05 23:00:54 INFO (MainThread) [hassio.addons] Startup application run 1 addons
17-10-05 23:00:54 ERROR (SyncWorker_19) [hassio.addons.addon] Addon core_configurator have wrong options -> Missing required option 'password'.. Got {'homeassistant_api': 'http://homeassistant:8123/api', 'homeassistant_password': '', 'username': 'admin', 'password': None, 'certfile': 'fullchain.pem', 'keyfile': 'privkey.pem', 'ssl': False, 'allowed_networks': ['192.168.0.0/16'], 'banned_ips': ['8.8.8.8'], 'ignore_pattern': ['__pycache__']}
17-10-05 23:06:33 INFO (SyncWorker_17) [hassio.dock.interface] Restart homeassistant/raspberrypi3-homeassistant
This error “Addon core_configurator have wrong options”
I will look into cause of error.
HI @Tinkerer,
looking for something else, i found your remark here.
Sounds like what i need for some other devices, but never found any hint to…
SO, what do you mean by that exactly, and how can one implement a timeout?
second, wold that be an option for lets say a NAs going off during night time, and starting up at daytime, and have the services (plex, iTunes) running on that timeout for that same period?
Would really be the answer to several of my issues here.
My comment was specific to that component.
