HASS does not boot up anymore component XXX took longer then expected
Nothing strange from log beside then “took longer then …”
017-10-04 18:58:43 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 18:58:45 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 18:58:54 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 18:58:59 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 18:59:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 18:59:05 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 18:59:06 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 18:59:11 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': '', 'type': 'Bool', 'genre': 'User', 'nodeId': 6, 'value': False, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 32, 'label': 'Exporting', 'readOnly': True, 'instance': 1, 'id': 72057594143605248}) for an unknown node 6
2017-10-04 18:59:11 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'kWh', 'type': 'Decimal', 'genre': 'User', 'nodeId': 6, 'value': 139.63999938964844, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 0, 'label': 'Energy', 'readOnly': True, 'instance': 1, 'id': 72057594143604738}) for an unknown node 6
2017-10-04 18:59:11 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'kWh', 'type': 'Decimal', 'genre': 'User', 'nodeId': 6, 'value': 139.63999938964844, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 1, 'label': 'Previous Reading', 'readOnly': True, 'instance': 1, 'id': 72057594143604754}) for an unknown node 6
2017-10-04 18:59:11 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'seconds', 'type': 'Int', 'genre': 'User', 'nodeId': 6, 'value': 301, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 2, 'label': 'Interval', 'readOnly': True, 'instance': 1, 'id': 72057594143604771}) for an unknown node 6
2017-10-04 18:59:12 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'seconds', 'type': 'Int', 'genre': 'User', 'nodeId': 6, 'value': 301, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 2, 'label': 'Interval', 'readOnly': True, 'instance': 1, 'id': 72057594143604771}) for an unknown node 6
2017-10-04 18:59:16 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 18:59:17 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': '', 'type': 'Bool', 'genre': 'User', 'nodeId': 6, 'value': False, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 32, 'label': 'Exporting', 'readOnly': True, 'instance': 1, 'id': 72057594143605248}) for an unknown node 6
2017-10-04 18:59:17 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'A', 'type': 'Decimal', 'genre': 'User', 'nodeId': 6, 'value': 0.0, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 20, 'label': 'Current', 'readOnly': True, 'instance': 1, 'id': 72057594143605058}) for an unknown node 6
2017-10-04 18:59:17 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'A', 'type': 'Decimal', 'genre': 'User', 'nodeId': 6, 'value': 0.0, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 21, 'label': 'Previous Reading', 'readOnly': True, 'instance': 1, 'id': 72057594143605074}) for an unknown node 6
2017-10-04 18:59:17 WARNING (Dummy-42) [openzwave] Z-Wave Notification ValueChanged ({'units': 'seconds', 'type': 'Int', 'genre': 'User', 'nodeId': 6, 'value': 301, 'commandClass': 'COMMAND_CLASS_METER', 'homeId': 4247933265, 'index': 22, 'label': 'Interval', 'readOnly': True, 'instance': 1, 'id': 72057594143605091}) for an unknown node 6
2017-10-04 18:59:21 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 18:59:21 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 18:59:27 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
what is wrong???
2017-10-04 19:09:45 WARNING (Thread-9) [custom_components.emulated_hue] Alexa type is deprecated and will be removed in a future version
2017-10-04 19:09:45 WARNING (Thread-9) [custom_components.emulated_hue] Listen IP address not specified, auto-detected address is 192.168.1.238
2017-10-04 19:09:46 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-10-04 19:09:46 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2017-10-04 19:09:46 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-10-04 19:09:54 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-04 19:10:04 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
    return fut.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/switch/broadlink.py", line 150, in setup_platform
    device_config.get(CONF_COMMAND_OFF)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/switch/broadlink.py", line 186, in __init__
    self._command_off = b64decode(command_off) if command_off else None
  File "/usr/lib/python3.4/base64.py", line 90, in b64decode
    return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
2017-10-04 19:10:07 ERROR (Thread-5) [rxv] Failed to fetch http://192.168.1.32:80/YamahaRemoteControl/desc.xml
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
OSError: [Errno 113] No route to host
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 356, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.4/http/client.py", line 1090, in request
    self._send_request(method, url, body, headers)
  File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
    self.endheaders(body)
  File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
    self._send_output(message_body)
  File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
    self.send(msg)
  File "/usr/lib/python3.4/http/client.py", line 859, in send
    self.connect()
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 166, in connect
    conn = self._new_conn()
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6c372310>: Failed to establish a new connection: [Errno 113] No route to host
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 438, in send
    timeout=timeout
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.32', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6c372310>: Failed to establish a new connection: [Errno 113] No route to host',))
  File "/srv/homeassistant/lib/python3.4/site-packages/rxv/rxv.py", line 92, in _discover_features
    desc_xml = self._session.get(self.unit_desc_url).content
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 531, in get
    return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 518, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 639, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 502, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.32', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6c372310>: Failed to establish a new connection: [Errno 113] No route to host',))
2017-10-04 19:10:07 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform yamaha
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
    timeout=timeout
    return fut.result()
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/yamaha.py", line 81, in setup_platform
    receivers = rxv.RXV(ctrl_url, name).zone_controllers()
  File "/srv/homeassistant/lib/python3.4/site-packages/rxv/rxv.py", line 87, in __init__
    self._discover_features()
2017-10-04 19:10:09 WARNING (Thread-11) [homeassistant.components.light.hue] Connected to Hue at 192.168.1.80 but not registered.
2017-10-04 19:10:11 ERROR (Thread-12) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.1.203, Hallway left: A socket error occurred when sending the command.
2017-10-04 19:10:18 WARNING (MainThread) [homeassistant.components.switch] Setup of platform broadlink is taking over 10 seconds.
2017-10-04 19:10:18 ERROR (Thread-7) [homeassistant.components.switch.broadlink] Failed to connect to device
2017-10-04 19:10:18 WARNING (Thread-6) [homeassistant.components.light.flux_led] Failed to connect to bulb 192.168.1.146, strip
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Percentage Today, the state is unknown.
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Queries Today, the state is unknown.
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Domains Blocked, the state is unknown.
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Livingroom Temperature, the state is unknown.
2017-10-04 19:10:22 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Office Temperature, the state is unknown.
2017-10-04 19:10:23 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_gilma_daily_energy_last_24h is already in progress
2017-10-04 19:10:23 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_gilma_daily_energy_from_0000_to_now is already in progress
2017-10-04 19:10:23 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_guest_room_daily_energy_from_0000_to_now is already in progress
2017-10-04 19:10:23 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_guest_room_daily_energy_last_24h is already in progress
2017-10-04 19:10:23 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:10:26 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:10:27 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_gilma_daily_energy_from_0000_to_now is already in progress
2017-10-04 19:10:29 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_guest_room_daily_energy_from_0000_to_now is already in progress
2017-10-04 19:10:33 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:10:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_moisture is taking over 10 seconds
2017-10-04 19:10:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:10:34 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:10:45 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:10:45 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:10:49 WARNING (Thread-8) [homeassistant.components.zwave] zwave not ready after 30 seconds, continuing anyway
2017-10-04 19:10:50 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:10:51 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.air_guest_room_daily_energy_from_0000_to_now is already in progress
2017-10-04 19:10:55 ERROR (Thread-11) [pynetgear] Error talking to API
File “/srv/homeassistant/lib/python3.4/site-packages/requests/models.py”, line 374, in prepare_url
scheme, auth, host, port, path, query, fragment = parse_url(url)
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/url.py”, line 199, in parse_url
raise LocationParseError(url)
requests.packages.urllib3.exceptions.LocationParseError: Failed to parse: None:None
  File "/srv/homeassistant/lib/python3.4/site-packages/pynetgear/__init__.py", line 113, in _make_request
    self.soap_url, headers=headers, data=message, timeout=10)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 112, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 504, in request
    prep = self.prepare_request(req)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 436, in prepare_request
    hooks=merge_hooks(request.hooks, self.hooks),
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/models.py", line 302, in prepare
    self.prepare_url(url, params)
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/models.py", line 376, in prepare_url
    raise InvalidURL(*e.args)
requests.exceptions.InvalidURL: Failed to parse: None:None
2017-10-04 19:10:55 ERROR (Thread-11) [homeassistant.components.device_tracker.netgear] Failed to Login
2017-10-04 19:10:55 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform netgear
2017-10-04 19:10:56 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:11:03 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:11:06 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:11:07 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:11:18 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:11:29 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:11:31 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:11:35 ERROR (Thread-7) [homeassistant.core] Error doing job: Future exception was never retrieved
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/synologydsm.py", line 114, in run_setup
    for volume in volumes:
TypeError: 'NoneType' object is not iterable
2017-10-04 19:11:40 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:11:47 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:11:51 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:12:02 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:12:08 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:12:13 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:12:24 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:12:31 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:12:33 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:12:34 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:12:49 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:12:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:12:56 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:07 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:10 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:13:18 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:29 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:40 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:47 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:13:51 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:13:51 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:13:51 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:14:01 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:14:04 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:14:12 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:14:12 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:14:19 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:14:23 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:14:34 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:14:45 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:14:53 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:14:56 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:15:06 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:15:10 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:15:14 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:15:16 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:15:17 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:15:28 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:15:39 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:15:50 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:15:51 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:15:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:16:01 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:02 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:16:12 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:12 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:16:15 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:16:16 WARNING (Thread-4) [netdisco.ssdp] Error fetching description at http://192.168.1.241:8200/rootDesc.xml
2017-10-04 19:16:16 WARNING (Thread-4) [netdisco.ssdp] Found malformed XML at http://192.168.1.30:9080: status=ok
2017-10-04 19:16:23 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:34 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:44 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:16:44 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:55 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:16:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:17:06 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:17:14 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:17:17 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:17:27 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:17:27 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:17:28 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:17:39 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:17:50 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:17:58 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:18:01 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:18:02 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:18:12 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:18:19 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:18:23 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:18:34 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:18:39 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:18:45 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:18:56 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:19:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:19:01 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:19:07 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:19:17 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:19:21 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:19:28 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:19:40 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:19:44 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:19:44 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:19:49 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:19:50 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:19:59 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:20:01 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:20:11 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:22 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:23 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:20:33 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:44 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:55 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:20:56 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:21:01 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:21:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:21:06 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:21:13 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:21:17 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:21:25 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:21:28 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:21:39 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:21:40 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-04 19:21:50 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:06 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-04 19:22:10 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:22:11 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2017-10-04 19:22:12 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:23 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:27 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-04 19:22:33 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:44 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:55 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2017-10-04 19:22:55 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:22:59 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-04 19:23:06 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
  2017-10-04 19:23:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
What platform are you running on, and what version of Home Assistant?
0.54 on a pi3 (hassbian)
until this morning was all ok
maybe I reinstall on top of it?
What would be the best procedure?
Is there anything else running on the Pi3?
You’ve got a bunch of errors:
  • the samsung one suggests you need to add a timeout line to your configuration
  • is your broadlink device switched on?
  • are you using the Netgear device tracker?
  • is your Yamaha device switched on, and does it still have 192.168.1.32 as its IP address?
I’ll leave it there, easiest to tackle problems one at a time
To reinstall, take a backup of your configuration, grab the Hassbian image, and re-write your SD card.
Doing so will erase your SD card and everything on it.
I have those errors lots of times, but hass still boots.
Samsung and Yamaha are off (as are many times).
Broadlink is on.
Yes Netgear is there and I use it
So, the question then is, how long have you waited, and what did you last do before it failed to start?
Hours, now like 3 hours.
I installed openhab, but both were working fine yesterday . Now I uninstalled openhab
installed the dev version same thing
2017-10-05 11:21:44 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-05 11:21:45 WARNING (MainThread) [homeassistant.setup] Setup of binary_sensor is taking over 10 seconds.
2017-10-05 11:21:46 WARNING (MainThread) [homeassistant.setup] Setup of climate is taking over 10 seconds.
2017-10-05 11:21:46 WARNING (MainThread) [homeassistant.setup] Setup of notify is taking over 10 seconds.
2017-10-05 11:21:46 WARNING (MainThread) [homeassistant.setup] Setup of camera is taking over 10 seconds.
2017-10-05 11:21:46 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-10-05 11:21:47 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-10-05 11:21:47 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2017-10-05 11:21:47 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-10-05 11:21:58 WARNING (MainThread) [homeassistant.components.updater] Running on 'dev', only analytics will be submitted
2017-10-05 11:22:02 WARNING (Thread-3) [custom_components.emulated_hue] Alexa type is deprecated and will be removed in a future version
2017-10-05 11:22:02 WARNING (Thread-3) [custom_components.emulated_hue] Listen IP address not specified, auto-detected address is 192.168.1.238
2017-10-05 11:22:02 ERROR (Thread-6) [homeassistant.components.sensor.netatmo] Module name: "Gilma_outdoor" not found
2017-10-05 11:22:08 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-05 11:22:30 ERROR (Thread-4) [rxv] Failed to fetch http://192.168.1.32:80/YamahaRemoteControl/desc.xml
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6dd302b0>: Failed to establish a new connection: [Errno 113] No route to host
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.32', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6dd302b0>: Failed to establish a new connection: [Errno 113] No route to host',))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.32', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6dd302b0>: Failed to establish a new connection: [Errno 113] No route to host',))
2017-10-05 11:22:30 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform yamaha
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
    timeout=timeout
    return fut.result()
2017-10-05 11:22:33 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
    return fut.result()
2017-10-05 11:22:33 WARNING (Thread-11) [homeassistant.components.light.hue] Connected to Hue at 192.168.1.80 but not registered.
2017-10-05 11:22:37 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2017-10-05 11:22:38 WARNING (MainThread) [homeassistant.components.switch] Setup of platform broadlink is taking over 10 seconds.
2017-10-05 11:22:38 ERROR (Thread-2) [homeassistant.components.switch.broadlink] Failed to connect to device
2017-10-05 11:22:54 WARNING (Thread-2) [homeassistant.components.light.flux_led] Failed to connect to bulb 192.168.1.146, strip
2017-10-05 11:23:02 ERROR (Thread-12) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.1.203, Hallway left: A socket error occurred when sending the command.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Percentage Today, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Domains Blocked, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Queries Today, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Livingroom Temperature, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Office Temperature, the state is unknown.
2017-10-05 11:23:04 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number:
2017-10-05 11:23:05 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:07 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:11 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:12 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:14 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number: unknown
2017-10-05 11:23:16 WARNING (Thread-5) [netdisco.ssdp] Error fetching description at http://192.168.1.241:8200/rootDesc.xml
2017-10-05 11:23:16 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 11:23:16 WARNING (Thread-5) [netdisco.ssdp] Error fetching description at http://192.168.1.247:1990/WFADevice.xml
2017-10-05 11:23:19 ERROR (MainThread) [homeassistant.components.telegram_bot.polling] Client connection error
2017-10-05 11:23:24 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:24 ERROR (Thread-5) [pynetgear] Error talking to API
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/models.py", line 374, in prepare_url
  File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/url.py", line 199, in parse_url
2017-10-05 11:23:24 ERROR (Thread-5) [homeassistant.components.device_tracker.netgear] Failed to Login
2017-10-05 11:23:24 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform netgear
2017-10-05 11:23:30 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:33 WARNING (Thread-9) [homeassistant.components.zwave] zwave not ready after 30 seconds, continuing anyway
2017-10-05 11:23:34 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 11:23:34 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2017-10-05 11:23:34 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 11:23:52 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
If you cannot identify failed component, easiest thing to do is comment out all component in configuration file then reenable one by one rebooting and verify HA start OK with each time new component enable.
This is easy if you have config split it into separate yaml file since you only need comment out “include” code in configuration.yaml.
If not using separate yaml file this is tedious but definitely better than chasing tail.
can’t be, it was perfectly working yesterday, no change in components.
Maybe the nework? How can I troubleshoot?
Look at this, what is this problem???
2017-10-05 23:33:17 ERROR (SyncWorker_3) [homeassistant.components.device_tracker.netgear] Failed to Login
2017-10-05 23:33:17 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform netgear
2017-10-05 23:33:19 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:33:21 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:33:32 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:33:34 WARNING (SyncWorker_13) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:33:39 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:33:45 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:34:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:34:05 WARNING (SyncWorker_6) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:34:13 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:34:15 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:34:16 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:34:21 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:34:30 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:34:36 WARNING (SyncWorker_4) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:34:41 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:34:44 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:34:47 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:35:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:35:07 WARNING (SyncWorker_8) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:35:12 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:35:13 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:35:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:35:18 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:35:23 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:35:37 WARNING (SyncWorker_18) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:35:38 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:35:46 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:35:48 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:36:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:36:08 WARNING (SyncWorker_17) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:36:17 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:36:19 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:36:25 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:36:29 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-05 23:36:39 WARNING (SyncWorker_0) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:36:48 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:36:50 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:37:06 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:37:10 WARNING (SyncWorker_6) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:37:11 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:37:19 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:37:21 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:37:26 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:37:34 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:37:37 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:37:41 WARNING (SyncWorker_6) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:37:50 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:37:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:38:06 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:38:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:38:12 WARNING (SyncWorker_15) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:38:18 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:38:21 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:38:22 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_temperature is taking over 10 seconds
2017-10-05 23:38:28 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:38:29 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:38:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:38:41 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:38:43 WARNING (SyncWorker_3) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:38:51 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:38:51 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:38:54 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:39:06 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:39:10 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:39:14 WARNING (SyncWorker_12) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:39:22 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:39:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:39:30 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:39:35 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:39:45 WARNING (SyncWorker_1) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:39:53 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:39:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:40:11 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:40:15 WARNING (SyncWorker_1) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:40:19 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:40:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:40:26 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:40:31 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:40:46 WARNING (SyncWorker_7) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:40:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:40:57 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:41:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:41:15 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:41:16 WARNING (SyncWorker_15) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:41:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:41:27 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:41:33 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:41:40 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:41:44 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:41:46 WARNING (SyncWorker_16) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:41:48 WARNING (SyncWorker_15) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:48 WARNING (SyncWorker_2) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:48 WARNING (SyncWorker_3) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:48 WARNING (SyncWorker_0) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:48 WARNING (SyncWorker_19) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:48 WARNING (SyncWorker_4) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:41:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:41:58 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:42:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:42:17 WARNING (SyncWorker_4) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:42:18 WARNING (SyncWorker_16) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:18 WARNING (SyncWorker_10) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:18 WARNING (SyncWorker_6) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:19 WARNING (SyncWorker_5) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:19 WARNING (SyncWorker_13) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:19 WARNING (SyncWorker_8) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:23 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:42:27 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:42:29 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:42:35 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:42:48 WARNING (SyncWorker_5) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:42:48 WARNING (SyncWorker_1) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:49 WARNING (SyncWorker_11) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:49 WARNING (SyncWorker_14) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:49 WARNING (SyncWorker_5) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:49 WARNING (SyncWorker_8) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:49 WARNING (SyncWorker_9) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:42:58 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:42:59 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:43:14 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:43:16 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:43:19 WARNING (SyncWorker_17) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:19 WARNING (SyncWorker_3) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:43:20 WARNING (SyncWorker_5) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:20 WARNING (SyncWorker_19) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:20 WARNING (SyncWorker_3) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:20 WARNING (SyncWorker_4) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:20 WARNING (SyncWorker_8) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:24 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:43:29 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:43:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:43:37 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:43:37 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:43:50 WARNING (SyncWorker_14) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:50 WARNING (SyncWorker_3) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:43:50 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:43:51 WARNING (SyncWorker_19) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:51 WARNING (SyncWorker_6) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:51 WARNING (SyncWorker_5) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:51 WARNING (SyncWorker_16) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:43:51 WARNING (SyncWorker_1) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:44:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_temperature is taking over 10 seconds
2017-10-05 23:44:11 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:44:11 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:44:18 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:44:21 WARNING (SyncWorker_2) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:44:21 WARNING (SyncWorker_10) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:22 WARNING (SyncWorker_4) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:22 WARNING (SyncWorker_8) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:22 WARNING (SyncWorker_9) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:22 WARNING (SyncWorker_7) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:31 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:44:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:44:39 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:44:51 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:44:52 WARNING (SyncWorker_9) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:52 WARNING (SyncWorker_16) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:44:53 WARNING (SyncWorker_3) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:53 WARNING (SyncWorker_18) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:53 WARNING (SyncWorker_13) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:53 WARNING (SyncWorker_17) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:44:53 WARNING (SyncWorker_19) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:45:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:45:15 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:45:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:45:23 WARNING (SyncWorker_14) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:45:23 WARNING (SyncWorker_12) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:24 WARNING (SyncWorker_15) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:24 WARNING (SyncWorker_4) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:24 WARNING (SyncWorker_18) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:24 WARNING (SyncWorker_0) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:30 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:45:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:45:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:45:40 WARNING (MainThread) [homeassistant.components.switch] Updating broadlink switch took longer than the scheduled update interval 0:00:30
2017-10-05 23:45:54 WARNING (SyncWorker_16) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:54 WARNING (SyncWorker_6) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:45:55 WARNING (SyncWorker_10) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:55 WARNING (SyncWorker_11) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:55 WARNING (SyncWorker_1) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:55 WARNING (SyncWorker_12) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:45:55 WARNING (SyncWorker_16) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:46:05 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
2017-10-05 23:46:13 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:46:16 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:46:21 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.marisol_heater is taking over 10 seconds
2017-10-05 23:46:25 WARNING (SyncWorker_0) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:25 WARNING (SyncWorker_19) [homeassistant.components.sensor.file] File or data not present at the moment: upslog.txt
2017-10-05 23:46:26 WARNING (SyncWorker_2) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:26 WARNING (SyncWorker_19) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:26 WARNING (SyncWorker_1) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:26 WARNING (SyncWorker_12) [homeassistant.components.sensor.netatmo] No data found for Gilma_Bedroom
2017-10-05 23:46:28 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Last Motion, the state is unknown.
2017-10-05 23:46:31 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:01
2017-10-05 23:46:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ceiling_right is taking over 10 seconds
2017-10-05 23:46:36 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flower_1_battery is taking over 10 seconds
I don’t understand. I changed SD card, installed Hassio, but similar problems stays
So maybe bootup OK but you cannot access web interface?
If so,
Try clear browser cache
Maybe try accessing from another device.
You say you new install Hass.io with same error.
Did you modify config or just install an try access it?
If fresh install with no change to config has errors, maybe network issue.
If fresh install but modify config, I still say try with unmodified config. This is faster troubleshoot method at this point.
I think of abandoning HASS all together. FOr me is impossible to rely my home automation like this
but what can be. Everything else works in the network
