HASS doesn't receive IFTTT Webhooks data
Hi, i want HASS do something via Google assistant, so i config IFTTT and HASS like this:
#ifttt settings
ifttt:
  key: c6_dNT5EUJA5ZlUCvXFsHIDDEN
#URL FROM WEBHOOKS SETTINGS: https://maker.ifttt.com/use/c6_dNT5EUJA5ZlUCvXFsHIDDEN
#------ INSTRUCTIONS FORM HASS-----------------"
# To send events to Home Assistant, you will need to use the "Make a web request" action from the IFTTT Webhook applet.
# Fill in the following info:
# URL: https://hidden.duckdns.org:8123/api/webhook/1df029986f034b6c869462e7024c129f75952054c60d1b025e3dd6071fHIDDEN
# Method: POST
# Content Type: application/json
# See the documentation on how to configure automations to handle incoming data.
# Created config for IFTTT Webhook.
#--------------------WEBHOOKS Make a web request:------------------------------
#URL: https://hidden.duckdns.org:8123/api/webhook/1df029986f034b6c869462e7024c129f75952054c60d1b025e3dd6071fHIDDEN
# Method:  POST
# Content-type: application/json
# Body: { "action": "call_service", "service": "fan.turn_on", "entity_id": "fan.bedroom_fan", "speed": "high" }
#----------------------------------automation settings-----------------
automation:
    platform: event
    event_type: ifttt_webhook_received
    event_data:
      action: call_service
#Want to test trigger, don't care about POST body, so I direct call a service.
    service_template: 'broadlink.send'
    data_template:
      host: '192.168.20.253'
      packet: 'JgC2ACYNKg0OKikOKg0PKQ4pDikOKg4pKg0OAAEIKg4pDg4pKg0qDg4pDikOKg4pDikqDQ4AAQgqESYODikqDSoNDykOKQ4pDikOKikODgABCCoNKg0OKikOKg0OKQ4qDikOKQ4pKg4OAAEIKQ4qDQ4qKQ4qDQ4pDioOKQ4pDikqDg4AAQgpDioNDiopDikODikOKg4pDikOKSoODgABCCkOKQ4OKSoNKg0OKQ4qDikOKQ4pKg0OAA0FAAA='
#Automation only work when I manual active via HASS User interface.
#When I press "Check now" to  check applet on IFTTT applet, no thing happend, nothing in hass log.
#Applet work OK,Google respond what i want after did command.
#To know HASS accept or refuse connection. I manual enter URL  https://hidden.duckdns.org:8123/api/webhook/1df029986f034b6c869462e7024c129f75952054c60d1b025e3dd6071fHIDDEN on browser, and It say: 405, Method not allowed. That's normal because I am getting, not POSTing.
#I can normaly access HASS by url: https://hidden.duckdns.org OR https://hidden.duckdns.org:8123
#HASS version 0.93.2
But nothing happen, nothing in HASS log.
Sorry. I didnt successful setting up SSL/TLS domain.
