I took a long time setting up HASS via docker on my Pihole and it was working fine. Life took over and now its several months later and I want to continue the project but the GUI isn’t up. It appears to still be running…
cat /usr/share/hassio/homeassistant/home-assistant.log
Doesn’t show anything obvious, just Spotify token errors from an integration I setup.
Is there a way to force an update or troubleshoot the docker container? I’m pretty new to Docker.
Where do I start looking? I have rebooted the Pi, done an apt get & update on the host OS. I’m not really sure whether I also need to log into the container and do the same.
Edit: Have tried the firewall steps in Troubleshooting installation problems - Home Assistant
