Hi everybody,
this is just some yaml
code for a card that will display whether there are HASS or HACS updates (and if there are HACS updates, show the amount). If there aren’t any, the card will be invisible. It uses custom:button-card
to display the available updates, but you can use it without this as well.
Perhaps anybody has a use case for it. I check HACS regularly, but tbh forget to check if HASS updates are available (I used to have a card like this with my previous HASS instance, but forgot to recreate it when setting up on a new server… and every now and then realize that there is a newer version available - now I won’t forget to update any longer because the update card takes up a lot of space and is bright ).
EDIT: I added the current HASS version number to the card as well. You cannot see it in the example images, because I just changed the card now after posting the initial post.
Code at the bottom. Example images:
Both HASS and HACS updates
After updating one HACS integration
After updating all HACS integrations
After updating HASS
Code
type: vertical-stack
cards:
- type: conditional
conditions:
- entity: binary_sensor.updater
state: 'on'
card:
type: 'custom:button-card'
icon: 'mdi:swap-vertical'
color: '#41bdf5'
color_type: card
label: |
return states['binary_sensor.updater'].attributes.newest_version;
name: Update available
tap_action:
action: more-info
styles:
card:
- font-size: 24px
- type: conditional
conditions:
- entity: sensor.hacs
state_not: '0'
card:
entity: sensor.hacs
icon: 'mdi:unfold-more-horizontal'
color: '#f541d6'
color_type: card
show_label: true
show_name: false
label: |
return states['sensor.hacs'].state + " HACS Updates available";
tap_action:
action: more-info
styles:
card:
- font-size: 24px
