Hass.io 0.62.1, can't make snapshot. Error in supervisor log
What does this mean in the supervisor log?
WARNING (MainThread) [hassio.api.security] No valid Hass.io token for API access!
Also one of these…
WARNING (MainThread) [hassio.api.proxy] Unknown Home-Assistant API access!
I cannot make a snapshot and the first appears each time I try. I have only seen the second one once.
Supervisor at .88, and yes I have fully rebooted. home-assistant. log is clean.
Fresh of a power off reload. I did click create 2 times by mistake.
18-02-13 05:00:51 INFO (SyncWorker_5) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-samba with version 3.0
18-02-13 05:00:51 INFO (SyncWorker_3) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-rpc_shutdown with version 0.3
18-02-13 05:00:51 INFO (SyncWorker_4) [hassio.docker.addon] Start docker addon 03d23610/armhf-addon-dasshio with version 0.2.0
18-02-13 05:00:52 INFO (SyncWorker_12) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-ssh with version 3.3
18-02-13 05:00:53 INFO (SyncWorker_8) [hassio.docker.addon] Start docker addon hassioaddons/terminal-armhf with version 2.2.1
18-02-13 05:00:55 WARNING (MainThread) [hassio.api.security] No valid Hass.io token for API access!
18-02-13 05:00:56 WARNING (MainThread) [hassio.api.security] No valid Hass.io token for API access!
18-02-13 05:00:57 WARNING (MainThread) [hassio.api.security] No valid Hass.io token for API access!
18-02-13 05:00:58 INFO (MainThread) [hassio.api.security] /supervisor/ping access from a0d7b954_terminal
18-02-13 05:00:58 INFO (MainThread) [hassio.api.security] /addons/a0d7b954_terminal/info access from a0d7b954_terminal
18-02-13 05:00:59 INFO (MainThread) [hassio.api.security] /supervisor/ping access from a0d7b954_terminal
18-02-13 05:00:59 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_terminal
18-02-13 05:01:02 INFO (SyncWorker_1) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi2-homeassistant with version 0.62.1
18-02-13 05:03:22 INFO (MainThread) [hassio.homeassistant] Detect a running Home-Assistant instance
18-02-13 05:03:22 INFO (MainThread) [hassio.addons] Startup application run 1 addons
18-02-13 05:03:22 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant/armhf-addon-configurator docker application
18-02-13 05:03:26 INFO (SyncWorker_18) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-configurator with version 0.2.6
18-02-13 05:03:31 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-02-13 05:03:31 INFO (MainThread) [hassio.core] Hass.io is up and running
18-02-13 05:03:53 INFO (MainThread) [hassio.snapshots] Full-Snapshot 04ed819a start
18-02-13 05:03:53 INFO (MainThread) [hassio.snapshots] Full-Snapshot 04ed819a run 9 addons
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_duckdns
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_rpc_shutdown
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon a0d7b954_terminal
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_check_config
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_ssh
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_mosquitto
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_samba
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_rpc_shutdown
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_configurator
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_check_config
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_samba
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_mosquitto
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_configurator
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_terminal
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_ssh
18-02-13 05:03:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_duckdns
18-02-13 05:04:10 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-02-13 05:04:13 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-02-13 05:04:18 ERROR (MainThread) [hassio.snapshots] It is already a snapshot/restore process running
18-02-13 05:04:37 WARNING (MainThread) [hassio.api.security] No valid Hass.io token for API access!
im getting same:
18-03-14 23:59:37 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request initialze
18-03-14 23:59:37 WARNING (MainThread) [hassio.api.proxy] Unauthorized websocket access!
18-03-14 23:59:38 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request running
18-03-14 23:59:38 WARNING (MainThread) [hassio.api.proxy] Unknown Home-Assistant API access!
what this means?
