Home Assistant 0.80.3 is available
You are currently running version 0.79.3
Well, if I click UPDATE from GUI, the process fails, and the log says:
18-10-20 14:50:45 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.80.3 18-10-20 14:50:45 INFO (SyncWorker_17) [hassio.docker.interface] Update Docker 0.79.3 with homeassistant/raspberrypi3-homeassistant:0.80.3 18-10-20 14:50:45 INFO (SyncWorker_17) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.80.3. 18-10-20 14:50:47 ERROR (SyncWorker_17) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.80.3 -> 500 Server Error: Internal Server Error ("readlink /var/lib/docker/overlay2/l: invalid argument").
Could you please help to understand why it fails? Is there any other method to update other than GUI?
DAMN! Same error updating from 0.80.3 to 0.81.0b1. Very frustrating since to update from 0.79 to 0.80.3 I had to install hass.io from scratch:
ERROR (SyncWorker_1) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.81.0b1 -> 404 Client Error: Not Found (“manifest for homeassistant/raspberrypi3-homeassistant:0.81.0b1 not found”).
