I did a brand new install of Hass.io on my pi3b (had HA running there for about 2 years now), just to have a clean install. I can’t get the customize hidden to work?
customize:
sun.sun:
hidden: true
I have also done the customize: !include customize.yaml
And used the UI to hide with no luck.
I can change icons and custom name and and. But no hidden?
Has anyone else seen this?
tom_l
October 5, 2019, 12:16am
2
That is only relevant for the older states display not Lovelace. For Lovelace you just don’t include the entity in a card.
francisp
(Francis)
October 5, 2019, 4:40am
3
I haven’t tried with sun yet, but I do have quite a few entities hidden in .99.3. I still have not created a customized lovelace ui, but with the automatic created view it works.
customize.yaml
input_boolean.light_back_hidden:
hidden: true
input_boolean.light_back:
hidden: true
calendar.feestdagen_in_belgie:
hidden: true
calendar.p_k:
hidden: true
calendar.pmd:
hidden: true
calendar.afval:
hidden: true
automation.rfbridge_demultiplexer:
hidden: true
automation.status_bij_opstarten_ha:
hidden: true
timer.timerlichtbovenoverloop:
hidden: true
timer.timerlichtwaskot:
hidden: true
automation.licht_waskot_af:
hidden: true
automation.licht_bovenoverloop_af:
hidden: true
light.lichtslaapkamervooraan:
hidden: true
light.lichtbovenoudeslaapkamer: {}
light.lichtslaapkamervooraan2:
hidden: true
script.scriptlichtslaapkamervooraan2af:
hidden: true
script.scriptlichtslaapkamervooraanaf:
hidden: true
light.lichtvooraankleinelichten:
hidden: true
light.lichtvooraangrotelichten:
hidden: true
light.lichtvooraandeur:
hidden: true
script.scriptlichtvooraandeuraf:
hidden: true
script.scriptlichtvooraangrotelichtenaf:
hidden: true
script.scriptlichtvooraankleinelichtenaf:
hidden: true
sensor.lichtvooraandeur_status:
hidden: true
sensor.lichtvooraangrotelichten_status:
hidden: true
sensor.lichtvooraankleinelichten_status:
hidden: true
sensor.lichtslaapkamervooraan_status:
hidden: true
sensor.lichtslaapkamervooraan2_status:
hidden: true
automation.zigbee2mqtt_log_level:
hidden: true
automation.rfbridge_demultiplexer2:
hidden: true
switch.switchkamerschuindak:
hidden: true
binary_sensor.updater:
hidden: true
device_tracker.aa_a0_01_0b_d5_cb:
hidden: true
automation.rflink_log:
hidden: true
binary_sensor.sensortvboven:
hidden: true
automation.rfbridge_log:
hidden: true
automation.purge_recorder:
hidden: true
all works.
thank you guys
I did that then it looks like this
This is if I just take it out.
If i say hidden: true
It just ignores the code.
sun.sun:
Friendly_name: Sun
hidden: true
device_tracker.nico:
hidden: false
device_tracker.zeca:
hidden: false
device_tracker.helena_vdwalt:
hidden: false
#Switches and lights
light.pc_lights:
icon: mdi:led-variant-outline
switch.pc_room_led:
icon: mdi:desktop-classic
switch.braai_room:
icon: mdi:radiator
switch.entry_light:
icon: mdi:door
switch.outside_led:
icon: mdi:led-strip
switch.outside_lights:
icon: mdi:spotlight
switch.tv_room_light:
icon: mdi:television-classic
#light.led_lights:
# icon: mdi:led-strip
input_select.holiday_led_effect:
icon: mdi:format-list-checks
input_number.animation_speed:
icon: mdi:speedometer
switch.pool_pump:
icon: mdi:pool
#Sensors
sensor.kw_total:
friendly_name: 'Total kW'
icon: mdi:alpha-w
sensor.pow_current:
friendly_name: 'Amps'
icon: mdi:alpha-a
sensor.pow_voltage:
friendly_name: 'Volts'
icon: mdi:alpha-v
sensor.kw_today:
friendly_name: 'kW Today'
icon: mdi:alpha-w
sensor.kw_yesterday:
friendly_name: 'kW Yesterday'
icon: mdi:alpha-w
as you can see all my other Customize works
francisp
(Francis)
October 5, 2019, 5:19pm
7
Well, I just tried. After a restart sun is not visible anymore.
Mutt
(Muttley)
October 5, 2019, 6:20pm
8
Tom answered your question. Are you using lovelace ? Then ‘hidden’ no longer works.
If you use lovelace just don’t include the entity.
It only works on the older ‘states’ display.
francisp
(Francis)
October 5, 2019, 6:48pm
9
Question : if you never customized your ui, the URL on HA shows IP:8123/lovelace/default_view . Is that the old ‘states’ view, or an automatic generated lovelace view ?
It says Lovelace in the URL. It’s Lovelace. If it was states it would say states
Yes its lovelace. Very weird.
francisp
(Francis)
October 6, 2019, 12:25pm
12
Anyway, hidden works. Tested it.
Hi thank you.
What i did in the end was to go to Raw config editor in lovelace and took it out of the code and its gone now.
Realy thank you for all the help and testing.
Fixfinn
(Finn Nielsen)
October 10, 2019, 2:09pm
14
Hi.
Just looking at your solution. What do you mean by Raw config editor?
I cant find it in lovelace UI
Thank You
/Finn
Hit the 3 dot menu in upper right. Configure UI. Hit the 3 dot menu again. Raw editor
Fixfinn
(Finn Nielsen)
October 10, 2019, 2:13pm
16
I got a lot to learn yet.
