I’m trying to add a 4TB usb drive (NTFS formatted) and mount and use via media browser.
Looking at the logs I see: Volume size (3TiB) too large for this architecture. Maximum supported 2TiB. Sorry
sudo apt-get install ntfs-3g should solve my problem but hass.io is locked down thus not possible.
Any ideas/suggestions? I do not want to re-format the drive and want to use it as NTFS.
Unfortunately no, I don’t think that has been added to the 64bit image.
It is rubbish anyway. It’s ok for switch outputs but binary sensor inputs regularly miss transitions back to the inactive state if the pulse length is shorter than a second or so. That issue has been open since Nov 2017. So don’t expect it to be fixed any time soon.
I’ve been using 64-bit HassOS for a while now, controlling a fan over GPIO without issue.
Not as precise an operation as monitoring switches and sensors, so your mileage may vary, but is a step in the right direction.
If you need the i2c pins, you’ll need to enable them specially though
