TasUI
TasUI is a zero-install device management interface web application for all your Tasmota devices.
It will discover your deployed devices and allow you to set up and configure every device from a single dashboard.
This initial version includes multiple views (Control, Health, Firmware, Wi-Fi, & MQTT) to allow you to quickly assess the state of your devices. There is also a detailed view (e.g., SetOptions, Status, etc.) available.
TasUI provides a syntax-aware command interface for every Tasmota command by category (e.g., Configuration, Timers, Sensors, Lights, etc.) as well as the “familiar” Console interface to enter commands directly. This is a beta version (i.e., we expect you to find some unexpected features).
TasUI is now available as a Home Assistant addon and Docker containeror now)!
The amd64
, arm32v7
, arm64v8
, and i386
architectures are currently supported. No configuration is required. The Home Assistant addon can be installed by adding the repository https://github.com/iotreboot/TasUI
to the addons list. The addon will be automatically updated when a new TasUI version is available. As for now, TasUI can’t work with Ingress or over https.
If you prefer to use TasUI directly from a Docker container, use the following commands:
docker pull iotreboot/tasui:latest
docker run -p [PORT]:80 iotreboot/tasui:latest
Replace [PORT] with your preferred port. For example:
docker run -p 8199:80 iotreboot/tasui:latest
Then, to run TasUI from the container, open a browser with http://localhost:[PORT]
or http://[IP]:[PORT]
You can also invoke TasUI via http://tasui.shantur.com/. The JavaScript is loaded to the browser from this web server but all traffic and access to your Tasmota devices is local. None of your device information leaves your network.
