For some reason the rest-server loses connection every time my xbox gets turned off. Restarting the rest server fixes it, but I need to do that every single time I turn the xbox off. Sometimes it does work but most of the time it doesn’t and will throw messages like:
Send connect request: failed.
Crazy thing is, when I turn it on via the rest server it will turn on, however state will remain at “on” even when it is “off” until I restart the xbox-rest-server
Same situation in my setup.
I wonder if it just miss the manifest.json file. But I have no idea how that should look like in this case. I had same issue with the hue sensors and manifest file soled it.
Right, I’ve not had this working at all, and I’ve rolled back to 0.91.4 and now the media_player component has showed up. I’m sure they’ve changed the way media_player components are loaded.
I’ve noticed another issue, is that in the python script you’ve set the default host for the smartglass service to ‘localhost’, which resolves to ::1 on my server, and that caused any attempts to contact endpoints to fail. I’ve changed this to 127.0.0.1 and everything now works well!
19-04-27 14:10:06 ERROR (SyncWorker_16) [hassio.docker.interface] Can’t install hunterjm/hassio-armv7-xboxone:2.0.0 -> 404 Client Error: Not Found (“pull access denied for hunterjm/hassio-armv7-xboxone, repository does not exist or may require ‘docker login’”).
I have it working under HA 0.92.1. Had to create the manifest.json and __init__.py files and place in the custom_components\xboxone folder. Mine are the same as @martydingo
Also had to re-authenticate with Xbox Live again, then it started working.
Edit: I forgot that Markdown uses double underscores as bold, so the __init__.py file wasn’t displayed in the post correctly. Remember to name the file as __init__.py – it must have the double underscore before and after the ‘init’ word.
For some reason @hunterjm 's repository isn’t allowing pull requests. So, you either need to make your own fork and use that github url in the add-on store, or (if you aren’t familiar enough with github) you can just use the one I already made here: https://github.com/jmhill1287/hassio-addons
NOTE: if you make your own fork there is an additional step of editing the config.json file by removing line 10 which reads “image”… which throws an error cause it is trying to find an image from the original repository.
The way custom component are handled has changed in a recent update so I implemented @dwinnn 's suggestions of creating a manifest.json file and placing it in the custom_components\xboxone folder. You should just copy and paste his code into the .json file. The only reason to change it is if you don’t want your component to be called xboxone.
Also from @dwinnn you need to creat a init.py file in the same folder as step 2. Again, just copy and paste his code into the .py file.
Once I did that (again, in addition to the set of instructions at the first repository) I have it up and running smoothly. Even got it loaded into homekit so I can do some rudimentary controls in iOS with siri.
@jmhill1287 Thank you! This worked for me perfectly. I was able to get it up and running but can’t edit the config with my Xbox login info but this is better than nothing.
I have control of the Xbox and can power it on and off but can’t get the Media Player to display any information from what the Xbox is doing.
19-05-04 18:28:08 ERROR (SyncWorker_4) [hassio.docker] Can’t create container from addon_835de24f_xboxone: 404 Client Error: Not Found (“No such image: 835de24f/armv7-addon-xboxone:latest”)
After installing en starting your add-on it shows me this log:
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Xbox One
Control your Xbox One from your Home Assistant device
Add-on version: 2.0.0
You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[21:44:33] ERROR: Unknown HTTP error occured
System: (armv7 / raspberrypi3)
Home Assistant version: 0.92.2
Supervisor version: 162
Please, share the above information when looking for help
or support in e.g, GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2019-05-04 21:44:40,087] INFO in rest_server: Starting Xbox Smartglass REST server started on 0.0.0.0:5557
[2019-05-04 21:44:40,089] DEBUG in rest_server: Setting tokenfile path to /root/.local/share/xbox/tokens.json
[2019-05-04 21:44:40,091] INFO in rest_server: Trying to load & refresh tokens
[2019-05-04 21:44:40,117] INFO in manager: Loaded token <class 'xbox.webapi.authentication.token.AccessToken'> from file
[2019-05-04 21:44:40,119] INFO in manager: Loaded token <class 'xbox.webapi.authentication.token.RefreshToken'> from file
[2019-05-04 21:44:40,121] INFO in manager: Loaded token <class 'xbox.webapi.authentication.token.UserToken'> from file
[2019-05-04 21:44:40,123] INFO in manager: Loaded token <class 'xbox.webapi.authentication.token.XSTSToken'> from file
[2019-05-04 21:44:40,142] DEBUG in connectionpool: Starting new HTTPS connection (1): login.live.com:443
[2019-05-04 21:44:40,853] DEBUG in connectionpool: https://login.live.com:443 "GET /oauth20_token.srf?grant_type=refresh_token&client_id=0000000048093EE3&scope=service%3A%3Auser.auth.xboxlive.com%3A%3AMBI_SSL&refresh_token=MCXb5INr%2AAi9utovyBlb0LgoWRMUu6ITToWAKXrQ4r168AoFe%2AOHam8XWbgqHVUJ2dcZyMUL0HQdOFFxuiSZDTAMgz4pZOw7oVYx%2AANDHtG%2AvhnJmU6Nj19jc1t4ctHrC9zB5lvoItYZ9fwG59LEge3KIlZ%21HcrIJJHGRr1AZpWjZXIws4%21L2bq%2Ay%21h0onZ84D0IES%21B3bTxz6V5f1up93mUugnqyku8jSorhmsmrZ%2Ad8VB0CV4nLlGtn4VpzkMw5pjOHqLJSey2%21s6%21AN7%2APY6RzgyHr3g9mRSF%2A%2ACkBnN4BNwWQfDGINAofSFcWWWBXDQ%24%24 HTTP/1.1" 200 1520
192.168.25.119 - - [2019-05-04 21:45:15] "GET / HTTP/1.1" 200 1129 0.009570
192.168.25.119 - - [2019-05-04 21:45:15] "GET /favicon.ico HTTP/1.1" 404 341 0.012459
[2019-05-04 21:45:52,705] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:45:53,213] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:45:53,720] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:45:54,228] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:45:54,731] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:45:55,247] WARNING in consolewrap: Failed to import NanoManager (depends on xbox-smartglass-nano). /nano endpoint will not work!
192.168.25.119 - - [2019-05-04 21:45:55] "GET /device HTTP/1.1" 200 514 2.562613
192.168.25.119 - - [2019-05-04 21:45:55] "GET /favicon.ico HTTP/1.1" 404 341 0.005900
[2019-05-04 21:46:33,610] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:46:34,112] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:46:34,623] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:46:35,133] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
[2019-05-04 21:46:35,640] DEBUG in protocol: Received DiscoverResponse from 192.168.25.14
REFRESH
And I cannot find the media control for my XBOX.
I also see this message
Integration xboxone not found when trying to verify its media_player platform.
When verifying this code for the media_player:
media_player:
- platform: xboxone
device: !secret xbox_device
In the log of the XBOX One Plugin:
[2019-05-04 21:53:48,028] WARNING in consolewrap: Failed to import NanoManager (depends on xbox-smartglass-nano). /nano endpoint will not work!
