Hi everybody,
I have loaded the related node-red addon in hass.io. when I check the log I have these errors and node-ren does not start.
Add-on version: 3.1.4
You are running the latest version of this add-on.
System: HassOS 2.12 (armv7 / raspberrypi3)
Home Assistant version: 0.94.4
Supervisor version: 166
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[13:49:36] FATAL:
[13:49:36] FATAL: SSL has been enabled using the ‘ssl’ option,
[13:49:36] FATAL: this requires a SSL certificate file which is
[13:49:36] FATAL: configured using the ‘certfile’ option in the
[13:49:36] FATAL: add-on configuration.
[13:49:36] FATAL:
[13:49:36] FATAL: Unfortunately, the file specified in the
[13:49:36] FATAL: ‘certfile’ option does not exists.
[13:49:36] FATAL:
[13:49:36] FATAL: Please ensure the certificate file exists and
[13:49:36] FATAL: is placed in the Hass.io ‘/ssl/’ directory.
[13:49:36] FATAL:
[13:49:36] FATAL: In case you don’t have SSL yet, consider getting
[13:49:36] FATAL: a SSL certificate or setting the ‘ssl’ option
[13:49:37] FATAL: to ‘false’ in case you are not planning on using
[13:49:37] FATAL: SSL with this add-on.
[13:49:37] FATAL:
[13:49:37] FATAL: Check the add-on manual for more information.
[13:49:37] FATAL:
[cont-init.d] nginx.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
Copy to clipboard
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
