Seeing how WPA2 might not be that safe by itself, having the possibility to use SSL would be nice, even on your home network.
As of now I’m using my patched appdash.py and dashboard.jinja2 with nginx SSL proxy to access the dashboards with https both on my local network and from the internet. Seems to be working just fine.
Hi all. I hope this post is related enough to be placed here. I’ve been struggling to get the + and - icons for the input_number widget in the dashboard.
I’ve now managed to get them working by adding fa-plus and fa-minus to the icon_up and icon_down part of the hadash_init.js file in the javascript folder within compiled. I’m just a bit surprised that the baseslider entities aren’t already setup. There isn’t anything populated for the style either and so the widget is displayed with a grey background. I’m confident I can adjust the file to get it working as I’d like but could someone tell me how these files are meant to work please? I get the feeling that I’m missing something in a different file that would cause these entities to be auto populated.
Thanks for your help already @ReneTode, I didn’t want to hijack your post any further so I headed over here.
i think that the release was a little to fast to get support for those who follow HA releases.
in the skinfiles the variables are still called input_slider instead of input_number.
i guess i thought a bit to simple and i said to @aimc that all he had to do was what he has changed.
Andrew the variables.yaml are not updated to input_number sorry for that.
I did the good-old ctrl-f replace to rename the input_slider to input_number in the variables file. I’m guessing the hadash_init.js file is generated from the variables file? I’m not going to do this now as I’ve got it working just as I’d like but, if I deleted the hadash_init.js file would it be re-generated when I loaded the dashboard? I’m just thinking that could be a solution if anyone else is trying to get the input_number widget configured i.e. rename input_slider to input_number in the variables file, then delete hadash_init.js then restart appdaemon in hass?
I haven’t got a clue how all this hass magic works. Maybe I’ll leave problem solving to you and Andrew
everything in the compiled dir is created automaticly.
and depending on your settings it gets recreated if you change something in your dashboards, or when you restart, or if the dashboard is loaded.
so yeah, only replacing in variables.yaml makes it right.
it has also to be changed in every custom skin by people using custom skins.
I have a few TPLINK (5x HS200, 1x HS105 and 1xHS110) and I had the same issue but now they work very well. . However to fix this, in your config file, ensure that the name of the device match the definition in the Kasa app.
And make sure your reserved the IP in your router.
@aherbjornsen… Hi…
I am also stuck at the same point with java error while getting state. Can you please explain the path of the appdash.py file and the changes so that I can get it working as a workaround as of now.
and I think that @aimc will provide an update version of hadashboard soon!!!
