Hass.io and Particulate matter Sensor (Nova PM, SDS011
I recently connected the Nova PM sensor, SDS011 (pictured) to one of the USB ports on my Raspberry Pi3.
I have added the following data to the sensors section of my configuration.yalm file
- platform: serial_pm
  serial_device: /dev/tty.SLAB_USBtoUART
  brand: novafitness,sds011
I have restarted my RPi3 and this is the error message that appears:
Could not open serial connection to /dev/tty.SLAB_USBtoUART ([Errno 2] could not open port /dev/tty.SLAB_USBtoUART: [Errno 2] No such file or directory: ‘/dev/tty.SLAB_USBtoUART’)
51XbIvd3RIL
Does anyone know what I’m doing wrong?
Thank you
Solved by serial_device: /dev/ttyUSB0
Hi Javier,
How does it work this sensor? I’m planning to buy a PMS5003 or this one. How about its precision?
TIA
Jordi
Considering the price, in my opinion, reliability is acceptable.
I have encountered two problems.
Sometimes (2 or 3 times a month), it seems as if the buffer gets stuck and then suddenly releases the contained data. With that 200 and 300 ppm data, we should be dead.
At high relative humidity percentages, the laser identifies some droplets as particles and slightly increases the measurements.
