Hass.io and VPN
I need a OpenVPN server and I’ve found out it is possible to install it on the same Pi as Home Assistant. Can somebody instruct me how to do this with hass.io installed?
Bump.
Also looking for this to enable external access to Hass.io behind carrier grade NAT.
I’d also be interested in how to get a VPN running in order to get access to the RasPi behind the NAT, anybody has a smooth solution?
This request is for CREATING a VPN SERVER.
You need a VPN CLIENT to connect to a SERVER outside your network.
