I am running Hass.io on a RPi 3B+. Trying to configure the AsusWRT device tracker. AsusWRT router is an Asus RT-N66U running AsusWRT Merlin v380.70 (the last supported version for its model.
Here is my configuration.yaml:
device_tracker: - platform: asuswrt host: 192.168.1.1 username: admin ssh_key: /config/.ssh/asus_key
When I ssh from the router itself, it works just fine (although the first time after a reboot, it requires confirming the host key):
But when home_assistant starts up, I get one of two errors. If it’s the first time starting after I reboot, I get a message that the file /root/.ssh/known_hosts does not exist. I understand that this is because Hass.io runs as a docker, so every reboot the /root/ files are reset and known_hosts are remove. How do I make it so that known_hosts persists through a reboot? Or is there a workaround I don’t know about?
Once I get the known_hosts file back in place, I get this error:
asyncssh.misc.DisconnectError: Disconnect Error: No matching key exchange algorithm found
I generally understand this has to do with the public/private key exchange between hosts, but when I ssh from the console, it works just fine. Every potential fix I’ve found revolves around adjusting /etc/ssh/ssh_config, but that file doesn’t persist, so a change there wouldn’t be helpful.
Can anybody help?
