Hi guys, I’ve been adding a new automation to push a PB notify to my phone, of when local wind speed and any of a small range of directions is valid. (like wind >25kmh and direction is N, or NNW, or NW).
In hass.io automation GUI there is an obvious option to add multiple conditions to an automation trigger, but not an obvious check box to make them ‘or’ or ‘and’ with the previous condition. It seems from looking at the my automations.yaml that it’s ‘anded’ by default.
Is there a way to ‘or’ all the conditions in the actual GUI without having to text edit stuff in the yaml file afterwards ?
Hope that makes sense…
Martin
I am having many of the same problems. Here is a link to my post (https://community.home-assistant.io/u/budlyte). I am beginning to think the CONDITION OR is not supported by hassio. I have tried every thing including automation right out of the documentation and nothing passes the config check. I also don’t think anyone on the forum has an answer so I am going back to multiple automations each checking one condition.
Interesting. I have a config that passes validation now and does load, but I’m yet to get a trigger result from it. That might be because the conditions of wind direction and speed have just not happened yet, but the longer it takes the more doubt I have…
Here is the code block that passes validation using OR conditions. Keep in mind that the sub block syntax ordering was originally created by hassio automation GUI (as default AND, then I edited to an OR manually), so it seems to read somewhat backwards in the order I’d have created it. (any comments about why that is ?)
