Hi all,
I’ve spent a lot of time trying different things and searching for stuff, but I simply cannot get this very simple thing to work. Im running on a rpi3 with hass.io version 62.1.
So, I have a TV that I want to pull some json information from, and for that I have set up a command_line sensor.
I can get the data i want by running this command in the terminal via SSH: curl -X GET -H 'Content-Type: application/json' '192.168.100.174:8080/BeoZone/Zone/Sources/' | jq '.sources[0] | .[1] | .product.jid'
This gives me this response: "[email protected]"
I tried to set this command into the command-line sensor with no luck. I’ve also tried to put the command into a .sh file and call it from the sensor with:
bash /config/scripts/beoinfo.sh
and also just
but all I get in the log is: Command failed: sh /config/scripts/beoinfo.sh
Can someone maybe point me in the right direction?
Thanks!
Christian
PS: The RESTful sensor does not work for the little project I’m trying to do, because I need to be able to change the TV’s IP address from the frontend But first I need to get the basics working!
