Hass.io component broken in 86
I have been using Hass.io in a docker so well for the past couple of months, infact I went through different installations and finally found the way to get access to the hass.io addon component where I can control every addon as well as update the system quickly by installing the Hass.io image inside a docker container. And I made the mistake of upgrading to 86 and now my Hass.io component is not intializing! The trouble I went through to get this working was like nothing else and now that messed up! Also, how do I turn off this lovelace thingy! Please help!
I’m not using hass.io, so i can’t tell you where to look, but you should read your logs.
There is a problem with entity_id’s that change and prevent hassio from starting.
If it runs, you can go back to the ols UI in Dev Tools/Info.
EDIT: Read the discussion on discord about it.
